Thread: Exhaust Down Pipe
Results 1 to 8 of 8
  1. #1 Exhaust Down Pipe
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey Forum,
    I am considering replacing the restrictive stock downpipe with a 2.5 inch one, what I want to know is, is there any sort of added fire danger from doing this? (going from a double walled pipe to a single walled pipe) Thanks in Advance and sorry if this isn't in the right place i couldn't find a sub section for exhaust.
    Last edited by tgarison; 08-09-2012 at 06:00 PM. Reason: I thought of something else to add
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Exhaust Down Pipe
    Houston
    If there were a fire danger, 90% of the peoples cars here would charcoal. The single wall is what helps them flow better.
  3. #3 Re: Exhaust Down Pipe
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    Double wall doesn't do **** except restrict your air flow. Go with 2.5 DP. Dont worry about your fire wall catching on fire lol. My car is still ok
  4. #4 Re: Exhaust Down Pipe
    Go 3in, make it worth your money.
    Stock is 2.25 with ubend, is the 2.5 really worth it?
  5. #5 Re: Exhaust Down Pipe
    Mar 2012
    San antonio
    if he goes 3 inch he could lose back pressure. Hes not SC. on zzp 2.5 and 3 in are same price
  6. #6 Re: Exhaust Down Pipe
    You know back pressure is a myth right?
    A normal running car with a fully stock exhaust creates less than 1 psi of back pressure.
    I run SD headers with the 3in downpipe with no cat converter and its as free flowing exhaust as you can get.
  7. #7 Re: Exhaust Down Pipe
    Ohio
    and i run open headers numerous times...back pressure aint ****
  8. #8 Re: Exhaust Down Pipe
    Mar 2012
    San antonio
    in that case im going with the headers with a 3 inch down pipe thanks
  1. Car idle jump and water from exhaust pipe
    By mcsddd in forum General Tech Discussion
    Last Post: 06-10-2012, 10:49 AM
  2. Size of exhaust pipe before cat
    By ryanm in forum 5.3L V8 (LS4)
    Last Post: 07-20-2011, 06:27 PM
