Thread: Another A/C Heat Problem
Results 1 to 9 of 9
  1. #1 Another A/C Heat Problem
    Jun 2013
    boston
    I have a 99 Grand Prix GTP with climate control. It had the problem where the water was dripping onto the passenger floor through the blower motor. The drain plug in the engine bay was clogged and when it rained it just dripped into the cab. And the rain diverter at the top of the hood, just under the windshield, was pouring the rain into the fan/blower. Anyways, I replaced that plastic piece so it no longer drips into the blower, and I unclogged the drain plug.
    The blower worked at that point, but now it doesn't work. I looked all over forums, it doesn't blow at all, not on high, not on low, not at all. I checked the blower and there is current going in and coming out. I checked the resistor and it was junk so I replaced it. It did not fix the problem. I checked the head unit connection and it looks great (no fried wires). I checked how many volts were going to the blower and it was real low, like 1 volt when it requires 7. So I replaced the head unit, still did not fix the problem. I am stumped at this point.
    Can anyone help me figure this out before I bring it to a mechanic? Kinda need heat for this below zero weather we are having in mass. This weekend it will be 50 so I'd like to have a last attempt.
    Thanks
  2. #2 Re: Another A/C Heat Problem
    Kinda sounds like the last step is to replace the blower motor itself, or swap it real quick with another if you know someone with another grand prix.
  3. #3 Re: Another A/C Heat Problem
    being you said it was pouring water via the old cowl, the blower motor may have taken a dump.
    did you try to spin the cage by hand at all? some times you can lube the shaft up and make it work for a while if its all rusted up.
  4. #4 Re: Another A/C Heat Problem
    Jun 2013
    boston
    The cage spins. Is there anyway to test the blower? I thought the multimeter test i did was good. I can go to a junkyard and grab a new one
  5. #5 Re: Another A/C Heat Problem
    Dec 2013
    If you unplug the blower motor and put a test light in the harness does it light? Bright or dim with the blower on high? You said it has climate control so i would assume it has a blower control module and not an actual resistor?
    Sent from my SCH-R970 using Tapatalk
  6. #6 Re: Another A/C Heat Problem
    Jun 2013
    boston
    yes, it has a control module.. here is the link http://www.rockauto.com/catalog/more...219&cc=1357130
    i do not have a test light yet, i will have to grab one this weekend. is it the harness that comes from the control module or the other one, that i test?
  7. #7 Re: Another A/C Heat Problem
    Dec 2013
    The one coming from the blower control module. Just unplug it from the blower motor and test it there. If the test light lights bright then you are looking at a bad blower. You can always hooke the blower up to the battery with jumper wires if you want to be sure. The blower control modules have three wires going in a power, a ground, and the signal that comes from the hvac module. The signal circuit is difficult to test and know what it should be, but between 1-6 is normal.
  8. #8 Re: Another A/C Heat Problem
    Jun 2013
    boston
    I bought a test light and checked the blower control module, and it lit up. I am not sure if the light would be considered bright or dim, but it lit up. Does this confirm the blower is junk?
    Is the blower motor the same in all grand prix's? Should I run to a junk yard or look online (ebay/rockauto)? The model on it says "52481316", is there an updated version?
  9. #9 Re: Another A/C Heat Problem
    Dec 2013
    If you connect the test light right to the battery that will show you what bright looks like (assuming your battery is not dead) but yes if the test light, lights at the blower connetor then you need a blower motor. Im not really sure what blowers are the same.
  1. No heat problem - 2000 GT
    By Demi in forum General Tech Discussion
    Last Post: 12-28-2012, 08:27 PM
  2. Heat Problem HELP!
    By kassel98gt in forum General Tech Discussion
    Last Post: 02-18-2011, 12:04 AM
  3. Heat Problem
    By holmz in forum General Tech Discussion
    Last Post: 12-07-2009, 08:34 PM
  4. Heat/fans problem getting worse
    By Freebeer187 in forum General Tech Discussion
    Last Post: 01-11-2009, 06:38 PM
  5. Cabin heat question - Possible problem
    Last Post: 11-13-2008, 08:42 AM
