So basically all full synthetic motor oils aren't "that great" then? Like pennzoil, castrol, mobil 1, valvoline.
Originally Posted by comatoast
Just a random thought... Do you guys think my overkill PCM might be causing issues with the cold weather with the fuel changes he makes in his PCM? Bad o2 sensor , ??
I just find it weird that it almost fires. It will crank , fire, crank, fire, but just not start. So close most of the time.. Then it floods from not starting... Maybe just swap back the original PCM, to see if it helps?
Any other suggestions?
It's definitely possible. If you still have the old one swap them and see.
2006 Grand Prix GT S/C 109k - Modded Transgo Shift Kit, Gutted Airbox, Dash Cam, and Inlays. Retros soon to come. 2002 Grand Prix GT N/A 127k - Same as 06 Plus: Trans Cooler, DIY Aux Input, LED lighting, Suspension Upgrades, Tint, Retrofits. Sold.
