Thread: Ok to go from a Synthetic oil, to a synthetic blend??
Results 1 to 20 of 26
  1. #1 Re: Ok to go from a Synthetic oil, to a synthetic blend??
    May 2008
    Schuyler, NE
    Actually they're not all the same. You can watch a video on youtube searching how oil filters are made. I've taken apart many filters over the past year and they're all the same style in theory with different quality levels pretty much. Some have paper end caps, some have metal. Some anti drain-back valves are rubber and can fail after 3k miles, and some are silicone and last a very long time. Some of the bypass valves are at the bottom of the can(not so good) and some are right at the top where the oil comes in. And the filter media changes slightly with each filter, they all like doing it a bit different. Again youtube has a bunch of videos of people taking them apart.
    Actually Ac Delco low level filters are pretty poor quality. They're comparable to a fram or maybe a little cheaper. Mobil 1 claims to be a full syn and what would make you think it's not that good of a synthetic oil?
    You are correct about ac delco. I didn't realize they were so bad.
    Here is a decent description as to why mobil 1 isn't fully synthetic.http://www.bobistheoilguy.com/forums...Number=2548209
  2. #2 Re: Ok to go from a Synthetic oil, to a synthetic blend??
    Dec 2012
    Where 4T65E's were born
    So basically all full synthetic motor oils aren't "that great" then? Like pennzoil, castrol, mobil 1, valvoline.
    Quote Originally Posted by comatoast View Post
    Just a random thought... Do you guys think my overkill PCM might be causing issues with the cold weather with the fuel changes he makes in his PCM? Bad o2 sensor , ??
    I just find it weird that it almost fires. It will crank , fire, crank, fire, but just not start. So close most of the time.. Then it floods from not starting... Maybe just swap back the original PCM, to see if it helps?
    Any other suggestions?
    It's definitely possible. If you still have the old one swap them and see.
    Sold.
  1. Synthetic Blend Motor Oil?
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2011, 11:15 AM
  2. Synthetic Oil
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-01-2011, 03:13 PM
  3. Synthetic oil
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2011, 04:15 PM
  4. synthetic oil the way to go?
    By Ryansgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 10:38 AM
  5. Synthetic Oil
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2009, 04:52 PM
