Thread: Synthetic Oil
Results 1 to 11 of 11
  1. #1 Synthetic Oil
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    I wanna know do any of you guys run full synthetic oil in your 3800s is it good bad? is there anything you should be aware of if your going switch to full synthetic? are there really any advantages of it. Please share your input
  2. #2 Re: Synthetic Oil
    run it.
    its better.
  3. #3 Re: Synthetic Oil
    Jun 2011
    Saginaw Mi
    lol that's what I wanted to hear I got a gallon of it dirt cheap yesterday I have always used the synthetic blend but have never taken the leap to full
  4. #4 Re: Synthetic Oil
    GT Level Member RegalGS98s's Avatar
    NJ
    If it has about 100k or less, I say run fully synthetic. I've been using Mobil 1 for years, but thinking of switching to Penzoil fully synthetic cause Mobil is a dirty oil. I've found if the engine hasn't been maintained or has high miles and has always had conventional oil run in it, changing it to synthetic may actually damage it. And if you were running synthetic and switch back to conventional, it may ruin the motor. Happened with my neighbor cause his buddy didn't tell him he ran synthetic.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  5. #5 Re: Synthetic Oil
    Those are myths.
    You know you can quite literally buy two quarts of synthetic and two quarts of conventional, mix them and run them with no issues?
    You can also mix weights.
  6. #6 Re: Synthetic Oil
    Jun 2011
    Saginaw Mi
    see now that just made me scared I have high miles
  7. #7 Re: Synthetic Oil
    Quote Originally Posted by str3etgl0w View Post
    Since you don't believe me, and believe that you will destroy your motor, go research it yourself.
  8. #8 Re: Synthetic Oil
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Those are myths.
    ^^^^^this I have done atleast half a dosen times
  9. #9 Re: Synthetic Oil
    Jun 2011
    Saginaw Mi
    I must have been typing that post while you responded I do believe you thats why I am gunna use it lol
  10. #10 Re: Synthetic Oil
    NJ
    Those are myths.
    I've seen on the oil company sites about the ability to run synthetic on higher mileage cars. They also claim the ethanol in gasoline isn't bad, but I've seen plenty of destroyed marine engines especially. But for the synthetic, I've noticed a lot more oil seepage at the seals on higher mileage engines and I have a Honda F22b2 engine sitting in my scrap pile that burned up the connecting rod bearings soon after switching to Mobil 1. It had about 150k on it. Also, if you have higher mileage on the engine, what's the point of switching to the more expensive fully synthetic. Keep using the oil you've used to get there, which I'd recommend Penzoil conventional oil. For a new engine though after it's been broken in, I absolutely recommend the fully synthetic.
  11. #11 Re: Synthetic Oil
    Grand Island, Nebraska
    I switched over to synthetic at 100k. The only problem is i think my valve cover leaked ONCE. I cant even prove that it was the oil because it happened 9 months and 5k miles later. It is also a very common problem (there was actually a recall for it.) I would still recommend it. If you get a good, long life filter I've heard you can go 7k or more between oil changes if you are comfortable with it. I reaserched it a lot also and I agree 100% with matt5112.
  1. Synthetic oil
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2011, 04:15 PM
  2. oil: synthetic or regular??
    By WHITEGPGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 06:46 AM
  3. synthetic oil the way to go?
    By Ryansgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 10:38 AM
  4. Synthetic Oil
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2009, 04:52 PM
  5. thinking about going synthetic
    By 04GTP in forum Off Topic Discussion
    Last Post: 03-20-2008, 04:24 PM
