You can take the two nuts off that hod the fuse block down. Pull it up a bit so it will flop around. Take the cover off the fuse block and that will give you the clearance you need. The side of the battery that faces towards the rear of the vehicle needs to come up first. The battery will then be on the other small side and will come right up.
Sent from my SCH-R970 using Tapatalk
