Thread: alternator question?
Results 1 to 10 of 10
lance4682 alternator question? 12-10-2013, 03:13 AM
BillBoost37 Re: alternator question? 12-10-2013, 06:46 AM
lance4682 Re: alternator question? 12-10-2013, 12:49 PM
BillBoost37 Re: alternator question? 12-10-2013, 01:02 PM
lance4682 Re: alternator question? 12-10-2013, 02:22 PM
BillBoost37 Re: alternator question? 12-10-2013, 02:48 PM
lance4682 Re: alternator question? 12-10-2013, 02:55 PM
nos4blood70 Re: alternator question? 12-10-2013, 06:47 PM
lance4682 Re: alternator question? 12-11-2013, 03:12 AM
slimguns Re: alternator question? 12-11-2013, 09:11 AM
  1. #1 alternator question?
    Nov 2012
    pistolvania
    i purchased a high output rebuild kit and pulley drop from asp wholesale and its not putting out anything at idle it will read about 12 .2 volts until i give it a little gas then it will jump up to 14.4......anyway was thinking about going to the junkyard to pick up a oem one until i figure out whats wrong with the rebuilt one.anyone know if there's a stock alt with higher amperage from another vehicle then what normally comes in a grand prix. i have a 99 gt
  2. #2 Re: alternator question?
    2000+ Bonneville SSEi, Park Avenue, maybe LeSabre
    Check that your field is on though. Meaning that the pcm is commanding the alt to produce voltage. In our tunes.. I believe it's set to turn off under 600rpm.
  3. #3 Re: alternator question?
    Nov 2012
    pistolvania
    so i would need to find a tuner to check that for me or could some one with a obd2 scanner look into that for me .....also thanks for the info
  4. #4 Re: alternator question?
    You could just go to a parts store and have them test things.
    Your rpm shouldn't be under 600 unless you have a serious cam etc.
  5. #5 Re: alternator question?
    Nov 2012
    pistolvania
    I'm stock but i will see what my rpm is set to.quick question i went to ebay looking for a used bonnie alt and there compatibility chart says i can't put it on my 99 gt
  6. #6 Re: alternator question?
    If you'd like I can show you the 2000 Bonnie alt on my 00 Regal. It's the same body alternator. Bolts right up and has more amps. Compatibility.. it'll work, but on stock charts..it's not going to show up.
  7. #7 Re: alternator question?
    Nov 2012
    pistolvania
    no its ok just wasn't sure
  8. #8 Re: alternator question?
    Jul 2012
    Chicago
    I could sell you a 2003 Bonne alternator if you'd like.
    -Carl
  9. #9 Re: alternator question?
    Nov 2012
    pistolvania
    how much shipped to 17408 and how many amps
  10. #10 Re: alternator question?
    May 2012
    Albuquerque, NM
    Just a thought but the 2003 impala l36 can use both the standard 100 amp as well as the police package 120 amp. That's what I planned on switching to when my alt dies in a couple months. In theory it should fit. I suggest you run by a parts store and size it up. It's not super high output but just enough to push a bit more electronics or run an under drive pulley with no loss (still a slight gain) of amperage. Your voltage should be the same across the board with the alts.
  1. Alternator/regulator question
    By DirtDog in forum General Tech Discussion
    Last Post: 07-12-2013, 11:35 AM
  2. alternator
    By Goldberg07 in forum General Tech Discussion
    Last Post: 07-13-2011, 03:31 PM
  3. alternator question
    By bluprix in forum Shops and Community Heroes
    Last Post: 07-16-2010, 01:59 PM
  4. Alternator question
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2010, 07:04 PM
  5. Alternator Voltage Booster question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2009, 07:23 AM
