Thread: Confirmed 0-60 with mods list
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
  1. #41 Re: Confirmed 0-60 with mods list
    SE Level Member hdnseek's Avatar
    Jun 2013
    Des Moines Iowa
    *ecu
    *unplug the sensor
    And when this is done the bottom port of the actuator remains vented to the atmosphere. You just want to cap the vac line coming from the solenoid.
    Sent from my HTC One mini using Tapatalk
  2. #42 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    And when doing front sway bar, make sure you spend the extra 10 dollars on the moog problem solver thermoplastic endlink and midpoint bushings, significant difference from stock rubber pieces
  3. #43 Re: Confirmed 0-60 with mods list
    GT Level Member Exile's Avatar
    Chicago
    I will check that link out. Definitely will get above OEM hardware when I do the sway.
    But would disabling TCS before launching yield almost the same benefits as doing this mod?
  4. #44 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    Idk I know my 97 doesn't have an option to disable it. If it senses loss of traction it cut all the boost. So I capped it and makes a huge difference. Just try it you'll most likely see some dofference
  1. mods list?
    By CountryBoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2013, 01:01 PM
  2. List of pointless mods
    By matt5112 in forum General Tech Discussion
    Last Post: 07-14-2012, 08:48 PM
  3. My Mods On JC [Updated To Do List 6-1-11]
    By jcmonteman in forum Members Rides
    Last Post: 06-14-2011, 10:50 PM
  4. New mods list
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:07 PM
  5. Last Opinions (INTAKE) and Mods List
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 12:17 AM
