Thread: Confirmed 0-60 with mods list
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Confirmed 0-60 with mods list
    SE Level Member hdnseek's Avatar
    Jun 2013
    Des Moines Iowa
    So about a month ago I went out and logged some 0-60 times on my ls1m logger and was having trouble getting it under 7 seconds. Since then I have capped the boost bypass solenoid, replaced the broken front sway bar on both ends with a 34 mm solid Dorman with all moog poly bushings. I also flipped my motor mounts. It is helping keep the car on the ground, but the capped boost bypass solenoid keeps boost even when no traction so I'm getting launching down. Other mods are 255 lph fp, u bend delete, resonator delete. Tonight was the first night I launched to 60 in under 6 at 5.94 seconds. Stock specs say 0-60 in 6.5- 6.7 but want to know what you guys are getting and what mods you have. Mine pretty much stock but let me hear your Input so I can relate if I have a decent time or not..
    Sent from my HTC One mini using Tapatalk
  2. #2 Re: Confirmed 0-60 with mods list
    Florida
    With my listed mods im doing 0-60 between 5.6-6 sec. Mainly the reason from wheelspin.and not fully tuned.
  3. #3 Re: Confirmed 0-60 with mods list
    GT Level Member Exile's Avatar
    Chicago
    According to my Torque app (uses OBDII readings & GPS) my 2001 GTP with just an intake does 6.9-7sec, depending on the temps. Best is 6.8.
    I think the Torque app is pretty accurate, I would put money on it being within 0.1sec.
    Under 6sec sounds like a new goal now, need more mods!
  4. #4 Re: Confirmed 0-60 with mods list
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    More mods, more power= more wheels spin and a lower time...lol
  5. #5 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    When plugged the vac line on the boost solenoid I finally saw full boost and it seems to get into boost quicker. The only thing is makes it extra hard to launch because the solenoid won't pull all the boost when you lose traction so....
  6. #6 Re: Confirmed 0-60 with mods list
    Howell, NJ
    I just went to check what my aeroforce said from the last run.
    5.72s
    I have zzp headers, gen v, stock throttle body stock pulley.
  7. #7 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    I'm going to pick up another m90 and lim today for porting and paint... So after I get everything ported out and cleaned up hopefully I can take another .1 off with my ported setup.. what's the best exhaust to complement ported? Was just going to get a plog but some say speed daddy are better for a full set of headers
  8. #8 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    And exile... I was also seeing intake temps below freezing during this run as well on an average night I can stick a 6.1 to 6.3. I really feel a difference with the suspension mods though, the swaybar and end links help put more power on the ground as well as those flipped dogmounts, they help the engine from rocking and solodfy it up. Huge difference and my lower motor mount is shot still. I would flip your dog mounts and cap that boost bypass solenoid and tell me if you feel a difference
  9. #9 Re: Confirmed 0-60 with mods list
    10.2 seconds.
    Spinning is winning.
    Mod list was (pulled from old FS ad)...
    Bulldog Racing Engines Balanced and Align Bored L67 3800 Series II V6
    ARP Head Studs
    ARP Main Studs
    Clevite77 Main/Cam/Rod Bearings
    Balance Shaft Deleted
    GM '04+ L32 Powdered Connecting Rods
    GM '04+ L32 TTY Rod Bolts
    GM '03 8.5:1 Compression L67 Pistons
    Thrasher Engineered Performance Race Camshaft (.574/.566 114 LSA)
    GM LS7 Lifters
    Comp Cams Rocker Arm Bolts
    Intense-Racing O/R Stock Length Pushrods
    Bulldog Racing Engines Custom Ported/Polished L67 Heads
    Manley #130 Valve Springs
    Manley Titanium Retainers
    GM OEM Valve Guides Milled .100" for cam clearance
    GM '04+ L32 Valves
    Comp Cams Valve Locks
    Viton Valve Seals
    Ported Lower Intake Manifold Inlet/Runners
    Ported Factory GM GenIII M90 Supercharger:
    -Rebuilt using OEM GM Seals/Fluids/Bearings
    -Ported Inlet/Outlet
    -Machined Supercharger Snout
    Custom LS1 Throttle Body Setup/Polished Adapter Plate
    LQ4 MAF Sensor w/ Open Cone Intake Setup
    ZZPerformance Modular Pulley System 2.8"/3.0"/3.1"
    ZZPerformance 160* Thermostat
    Custom HP Tuners Tuned PCM
    Pacesetter Headers:
    -2000* Resistant Armor Coated
    -1 7/8" Primaries - 3" Downpipe
    -Custom Welded 2 Piece Design
    -Catless
    Gene & Calvin's Custom Exhaust Setups
    1) Street Exhaust - 3" Custom Bent, GM Factory Resonator, Flowmaster 40 Series Mufflers, Roush Dual/Dual Racing Tips
    2) Offroad Exhaust - 3" Mandrel Bent Piping, 26" Glasspack, No Muffler, Dumped Behind Pass. Rear Tire (In Video)
    MSD Ignition Coil Packs
    MSD Ignition 8.5mm Spark Plug Wires
    Autolite 103 Copper Core Spark Plugs
    It also had a built trans from 3EP, 3.29's as well. Video was ran on the street obviously...with 255 wide NT555R's...in and out of throttle...pretty easy to tell when I mash back in it. I'm a horrible driver
    See video: http://s241.photobucket.com/user/blu...ml?sort=4&o=14
  10. #10 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    Damn wheelspin... Under six though... What bell can we do to minimize it run 10 wide tires??? And hella flush with coilovers lol
  11. #11 Re: Confirmed 0-60 with mods list
    My 40-100~ was faster.
    FWD blows.
  12. #12 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    Yeah I bet.. you kind of have to race everyone from a roll. But even then I bet you still have plenty of tea tion problems from under 40. I'm hoping a ported setup with a 3.2 meth and headers won't be that harsh to get launching down.. gotta dominate those stoplight bandits in Honda's and stuff lol
  13. #13 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    Someone should come up with a Awd system
  14. #14 Re: Confirmed 0-60 with mods list
    AWD would be dumb. Good luck.
    http://s241.photobucket.com/user/blu...tml?sort=4&o=3
    Yeah, need better tires.
    Feathering the throttle is key. I've found holding it in 1 until about 20~ seems to work well if you can keep it from blowing the tires off, that way it doesn't shift and bog. Once you've found the happy medium between spinning and traction...then put it in 3 and let the auto do the work.
  15. #15 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    I just leave it in drive with performance shift. You ease into it off the line and keep it right on the edge of no traction right until about 3-4k and then wot it helps a lot.. finding out that 2 nd will be a little tougher cause it's oon the border of tea tion shifting and around 30-40
  16. #16 Re: Confirmed 0-60 with mods list
    It goes with mods.
    Trust me. 3.2"~ with meth and bolt-ons is still pretty simple to drive. When you start digging into the valvetrain, changing gearing...things become more difficult traction wise.
  17. #17 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    I hear ya. Won't have money to get into valvetrain and the tranny stuff for a while.. still debating on whether to go full boar on mods with the gtp or leave it at a 3.2 and find a red autocross car..
  18. #18 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    Rwd
  19. #19 Re: Confirmed 0-60 with mods list
    Jun 2013
    Des Moines Iowa
    I had a twin turbo stealth before my gtp and it was a blast with the awd. I've heard that someone on this forum did a vr4 swap into a gtp.
  20. #20 Re: Confirmed 0-60 with mods list
    You heard wrong, lol.
    But that is pretty hysterical.
    RWD swap has been done quite a few times...it's just lolworthy with all the work involved.
  1. mods list?
    By CountryBoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2013, 01:01 PM
  2. List of pointless mods
    By matt5112 in forum General Tech Discussion
    Last Post: 07-14-2012, 08:48 PM
  3. My Mods On JC [Updated To Do List 6-1-11]
    By jcmonteman in forum Members Rides
    Last Post: 06-14-2011, 10:50 PM
  4. New mods list
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:07 PM
  5. Last Opinions (INTAKE) and Mods List
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 12:17 AM
