You heard wrong, lol.
But that is pretty hysterical.
RWD swap has been done quite a few times...it's just lolworthy with all the work involved.
Also...why have you capped the BBV?
Fix that.
Put a resonator back in your car too, they sound like ass without it. Fuel pump is overkill too, no need for it at your mod level...or for quite some time.
Capped the vac line coming off the sensor. See full boost now. Car sounds awesome with no res and stock mufflers. Fuel pump went out a while back and sense I'll be going e85 in the summer I got a good deal on a 255 and threw it in
Sent from my HTC One mini using Tapatalk
Are you driving a Cobra?
And no, car sounds like crap.
No but same principle.. it was only seeing 7.5 pounds before.. now I see 9 most times so I know it helps. And we I beg to differ on exhaust
The most horrible sound I've had exhaust wise on these car was my old 2000 with stock mufflers and no res, it was like that when I got it, so ****ing high pitched and raspy.
But to each their own, eh?
Because more boost is what you're wanting...
Do it the right way.
Get supporting mods and drop pulley sizes.
I get 0* of knock wot with it this way as well so not doing anything the wrong way.. plus I control the launch control. Rather have this setup this way versus stock. Losing all boost when launching vs keeping it at full boost and learning to launch it yourself. Before like a said 0-60 with solenoid better run was 6.9 now I'm getting 5.9 with out it
Biggest glasspack up middle to replace the resonator with, mufflers of your pick up behind(Stock, Tubos, Hookers, Borlas all get good results.) I've had good luck with with cheap Trush/Dynomax turbos on my old car, as long as the resonator is fat. Running glass pack + stock muffs on my Comp-G.
Personally I have looked at tons of exhaust videos and don't really like wasting weight and money when you can't make em sound good anyways. I'm going to run a exhaust cut out after cat and. Then two bullet race muffler to turn downs to save weight. Think if rather have a better performing exhaust than a better sounding
Anyone will tell you that the stock set up is good up to 350 wheel, if you want to save your ears, keep them stock and add a glasspack back in the middle. All I can say.
Yeah I hear ya, how much weight could be saved though from the rest if say the exhaust is turned down right before. The rear seats?
Correct
And some will realize its a Grand Prix not a racekar and that the amount of weight your going to save just by getting rid of the stock mufflers isn't going to help your car be that much faster.
Find a happy medium a car that will still hold its own and not make your ears bleed Everytime your forced to drive it
I realize it's a grand prix, just want the best flow to support mods. And save the weight to help the back not sag so much.. probably gonna save about 20 pounds with new setup.. still figuring the setup though to minimize how loud it'll be
If you're going to put a cutout on I'd install it before the cat myself, cutout is a good option. You can leave stock cat back on and have the choice of a loud car or a quiet one and have wide open flow from DP at the touch of a button. You can choose how loud/quiet you want it depending how far cutout is cracked open.
http://www.modularfords.com/threads/...ass-Mod-How-To
Heres the right way to do it.. I made it simple... There is one vacuum line that runs from the electronic solenoid to the boost bypass actuator, it the bottom line on the actuator. If you pop the line off the actuator and cap the line it will keep the car from bleeding off boost when in reverse and at top speed limiter as well as the use of it as traction control. The edu trigger the solenoid to cut boost by opening the actuator when no traction is suspected. And I found it useful because I'm actually able to hit full boost a little quicker and get off the line to because boost remains when launching. The car just feels more responsive to accelerating this way. You can also just unplug the ad Apr but it will throw a code. I'll get some pictures tomorrow
