Thread: Mysterious Wire Help
Results 1 to 13 of 13
  1. #1 Mysterious Wire Help
    Mar 2013
    NW Iowa
    I have a1999 Grand Prix GT and I have a mysterious wire coming out of my fuse box. It looks like a wire for an amp but as far as I know I don't have an amp. Looking towards your suggestions. Thanks
  2. #2 Re: Mysterious Wire Help
    SWPA
    Looks to be for an aftermarket amp. Previous owner may have had a system installed and only removed the amp and sub but left the wiring.
  3. #3 Re: Mysterious Wire Help
    Feb 2013
    37.295091, -121.930053
    Thats what the owner before me did. She had a system in the car and had to dump it so she tore it out and now I have to piece it back together again.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Mysterious Wire Help
    Mar 2013
    NW Iowa
    Where would look for an amp at? Would I notice through the stereo if there was an aftermarket amp?
  5. #5 Re: Mysterious Wire Help
    Feb 2013
    If you have a bose sound system look in the trunk just to the right of the third break light.
  6. #6 Re: Mysterious Wire Help
    Mar 2013
    NW Iowa
    I don't have the Bose sound. Just standard.
  7. #7 Re: Mysterious Wire Help
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    pull the fuse in the pic and see what happens
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  8. #8 Re: Mysterious Wire Help
    Mar 2013
    NW Iowa
    There isn't one in there. I tried putting a fuse in it a while ago and I didn't notice any difference in the sound.
  9. #9 Re: Mysterious Wire Help
    That would be a amp kit
    04 Comp G.
  10. #10 Re: Mysterious Wire Help
    Mar 2013
    NW Iowa
    Do you have any idea where the wire would go to? Do you have to have an aftermarket head unit to use an amp?
  11. #11 Re: Mysterious Wire Help
    GT Level Member WolvesSoulZ's Avatar
    Québec
    It probably goes in the trunk, like that place where everyone puts their subs in.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  12. #12 Re: Mysterious Wire Help
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    How about following the wire to see where it goes?
    If I had to guess I'd say it goes through one of the holes in the firewall then down under the carpet below the dash then back through to the trunk under the door sill trim. Pull up the carpet in either corner directly behind the rear seat, you may find the end of it there.
  13. #13 Re: Mysterious Wire Help
    Mar 2013
    NW Iowa
    It does go through the firewall. That's as far as I have followed it
  1. Mysterious dinging!?!?!
    By silverbullet10 in forum General Tech Discussion
    Last Post: 03-02-2014, 02:04 AM
  2. mysterious connector!?
    Last Post: 08-09-2011, 02:00 PM
  3. Mysterious grind only while braking
    By techweenie in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2011, 07:06 PM
  4. Mysterious coolant loss ...
    By timweidner in forum General Tech Discussion
    Last Post: 03-13-2010, 09:33 AM
  5. mysterious clicking
    By bennybravo in forum General Tech Discussion
    Last Post: 03-06-2010, 01:07 PM
