Thread: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the road!
Page 5 of 5 FirstFirst ... 345
Results 81 to 84 of 84
  1. #81 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    Feb 2009
    flintnasty MI
    I am using a late 90s N* maf sensor in a 97-98 style L67 throttle body and NO translator- even with this turbo at 17 psi I am only hitting 11,100hz so there is a bit of room left in it
    How much did you end up taking out of the maf table up in the top end?
  2. #82 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    What track are you going to?
  3. #83 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    hangover park IL
    HEYYA DAVE!
    figured it was time to bug ya, what with team moose knuckle showing 80e durability so far.
    been looking at the weakness's and it seems the sonnax fixes are it, however im looking at the pri/2ndary pumps and the pressure regulator/lube/converter circuits. everything i can see from the pics shows that sonnax doesnt change the 2ndary pump apply/bleed profile over the OEM valve, its just a larger OD for the reaming to remove the crosstalk/sticking.
    while it may be that the sonnax spring is stiffer, its also possible its not anything more than oem tension (which seems to vary...) so while a stiffer spring would up the pressure it looks like if you extend the 2ndary pump to exhaust shoulder you could keep the 2ndary pump more active while not drastically increasing conv feed/lube#2 pressure.
    i have a few vb/pump housings so far but im looking to aquire more. you have the jig for the sonnax stuff? we're looking to buy the kits so i can look at the sonnax stuff vs the oem. making a new PR valve would be easy.
    ive gotta order the actual damn manual but so far i see at least 1 fairly easy way to do a 1/3 trans brake with one external hyd line
    but its such a bastard following the circuits without good old fashioned hardcopies/foldouts
    80e fo lyfe
    regards, James
    ~James~ Psychotic Gearhead
  4. #84 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    Antioch, IL
    subbed
    2009 Challenger SRT8
    Expert at being gay.
  1. Check out my latest project...
    By Confusingboat in forum Off Topic Discussion
    Last Post: 06-23-2011, 05:20 PM
  2. 1997 Grand Prix GT- L67 Swap question(s)
    By kc50lx in forum General Tech Discussion
    Last Post: 04-02-2011, 07:53 PM
  3. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  4. Motor Swap in 1997 Grand Prix GT Coupe L36
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2009, 06:00 PM
