Thread: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the road!
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 84
  1. #1 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    found out that PI does 4t80e converters
    And guess who worked with them to lay out a custom 4T80E / 3800 S2 converter option.
    TCC controls are of no concern on the 4T80E. There is no TCC pressure switch in a 4L60E or 4L80E either, pwm will work fine. There is a switch option to use or not use the TCC switch in the pcm code. Shift solenoid state gets reversed. After that it is simply plugging in new iss and vss values to get the ratios correct. Getting the trans tuned with a 3800 pcm is a non issue for this project or I wouldn't have done it.
  2. #2 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Arizona
    Quote Originally Posted by Trannyman95 View Post
    What about this trans working with the t42 controller ? Seems most tables you mentioned are in out tunes as well. (Ls4)
  3. #3 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Banned
    Hello Dave!
    Love the project!
  4. #4 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    Thanks Brian! Its been a long time coming just not much time to work on it. Hope all is going well and your GTP is still running strong.
    In regards to an LS4 application - the big obstacle here is the starter. The LS4 already his a decent mount mount arrangement so some of that could be incorporated to this and in fact I wanted to use the front lower LS4 engine mount for this project as a base to rebuild a better one since the factory mounts are pretty weak and almost every one that comes in is torn in half. The holes were already in the frame (on the bottom side of this 97 frame) and after drilled the LS4 mount fit perfectly so I was hopeful but turned out the AC compressor and bracket was in the way so I started from scratch.
  5. #5 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    May 2012
    Where winter never ends
    What are the odds of us "home mechanics" being able to do this project successfully?
    2000 Regal - Winter Beater
  6. #6 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    Its been slow progress moving forward on this but I have done quite a bit the past month on the car. The turbo piping is almost finished up and a rear manifold is done to match the fitment of the new trans. I am using Aeromotive 3800 S2 fuel rails and had to make new brackets to fit the Fbody intake manifold so those are finished up, just need to plumb it. Hopefully in the next few weeks I will have this ready to fire. I will try to get some new pics posted up soon.
  7. #7 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    I live here. DirtDog's Avatar
    Jun 2012
    Sweet!!!
  8. #8 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Will be interesting to see how the price and ease of this swap vs the cost of a built 4t65 plays out certianly keeping my eye on this and cant wait to see how this goes!!
  9. #9 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    Finally got to start the engine yesterday. Lots of little things to finish this up that has been what seems like countless hours! Should be on the road in a few days. Rough tune is done so far just going over everything. Intercooler not installed yet but the engine will get several hundred miles put on it before any aggressive driving anyways since it is all fresh.
    Below is a finish pic underhood and a few others. A few odds and ends left that will get tidy'd up after we put some miles on it. I have tons of pictures of everything just need to sort through it.
  10. #10 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Looks sweet.
  11. #11 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Here take my wallet and make me another hotside and 4t80 retrofit kit...........
    I have a gutted tboned car at home that's begging to be rebuilt after getting hit, everything works as it should its just ugly.
  12. #12 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Oct 2011
    Puyallup WA
    Best looking turbo fbody intake setup I have seen...so clean!
    08 G8 GT - exhaust Tune
  13. #13 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
  14. #14 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
  15. #15 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    that tranny is a monster. hard to believe it fits.
  16. #16 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    Just took car for first drive around the block. Trans feels great thankfully! 160K miles on it and good solid shifts. Lots of tuning to do on engine but at least its on the road. Now just need to finish tune and go try to break it
  17. #17 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    It's alive!!!
  18. #18 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    How's this coming?
  19. #19 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    hangover park IL
    hey dave you stil planning on switching to the later 80e IMS?
    ~James~ Psychotic Gearhead
  20. #20 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the ro
    Fort Wayne, IN
    I am due for an update on the car. So far so good with the trans. I ran into a few minor things along the way that needed tweaked a bit but so far the trans has been working well. The temporary T70 on the car (TE60 being rebuilt due to turbine seal leaking) at 17 psi is a beast though the 2-3 shift at WOT is not the strongest so I have to play with that a bit more but there is more room in the tune to bump shift psi up a bit. Torque management is also completely turned off from some prior trial and error effort to sort out some odd behavior which turned out to be gear ratio vs gear related as the pcm always say 2nd gear slipping so would pull crazy amounts of timing out. A big downfall with this trans in stock form and in a vehicle is the ability to do anything for 3rd gear. The 3rd accumulator is in the valve body area in the side cover so you can't mess with it once in the car. If running max psi on the 2-3 shift isn't good enough then some work will need to be done to the trans before installing.
    James- no plans for newer trans with IMS at this point at least on our car. It would definitely free up some room for the exhaust and you wouldn't have to build a custom rear manifold like I did!
    Hoping to make it to the track soon with some numbers. The 245 Falkens on the front don't agree with this setup at all so waiting on MTs to come in. Currently at 50mph and not even going WOT it will haze the tires. Pulls like mad once you get through that and into 3rd gear though!
    More food for thought- I am using a late 90s N* maf sensor in a 97-98 style L67 throttle body and NO translator- even with this turbo at 17 psi I am only hitting 11,100hz so there is a bit of room left in it. Makes for a cheap upgrade with no modifications other than tuning. I will report back once I have some more time with the car and hit the track. It has about 1800 miles on it now.
  1. Check out my latest project...
    By Confusingboat in forum Off Topic Discussion
    Last Post: 06-23-2011, 05:20 PM
  2. 1997 Grand Prix GT- L67 Swap question(s)
    By kc50lx in forum General Tech Discussion
    Last Post: 04-02-2011, 07:53 PM
  3. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  4. Motor Swap in 1997 Grand Prix GT Coupe L36
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2009, 06:00 PM
