Thread: Help p2535 ignition switch run/start position circuit high
Results 1 to 2 of 2
  1. #1 Help p2535 ignition switch run/start position circuit high
    Sep 2013
    Minnesota
    Can this happen with loose battery cable? Dash lights flicker with no key in ignition? Thanks
  2. #2 Re: Help p2535 ignition switch run/start position circuit high
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    this is what my scanner says
    P2535, Ignition 1 switch circuit high voltage. Dtc sets when the ignition 1 voltage signal is higher than normal for more the 7 seconds.
    Check for a poor connection at the PCM and BCM.
    Disconnect the ignition 1 relay.
    Check the ignition 1 voltage circuit between the PCM and the ignition 1 relay for a short to voltage.
    Check the ignition 1 voltage between the BCM and the ignition 1 relay for a sort to voltage.
    If all the circuits are ok then suspect either the PCM, BCM or the ignition 1 relay.
    good luck
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Got some work to do where do I start.... Ignition switch.resistor...etc
    By chicagochuck in forum General Grand Prix Discussion
    Last Post: 08-05-2012, 03:01 AM
  2. Key comes out of ignition in every position.
    By LastPatriot in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 08:39 PM
  3. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  4. 2001 Grand Prix ignition switch position
    By davejt in forum General Tech Discussion
    Last Post: 06-15-2010, 11:07 PM
  5. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
