Quote Originally Posted by Jakegday View Post
i also purchased a spare key on ebay that claimed to come with programming instructions. keep in mind mine is a 2001
the instructions said to get the key cut first, (obviously) then you take your current key, put it in the ignition, turn the ignition to the RUN position, the position its in when your driving, then take that key out and put the new key in within 15 seconds and turn the ignition to the RUN position again. your new key should be ready! the instructions that came with mine said my alarm light would blink twice to confirm the new key was programmed but it never lit up throughout the entire process, and the new key works flawlessly
This is used to add a "duplicate" key (have original)
1) Insert the "Original" (working) Key.
2) Turn the Ignition to ON (RUN), but do NOT start the engine. Turn the Ignition OFF and remove the key.
3) Within 15 seconds insert the new "duplicate" key and turn the Ignition to the ON position. The Security indicator should light for about 2 seconds to indicate that the new key has been programmed.
4) The new key should now be able to start and run
this does work, it is for a pk3 key
