Thread: I need to no were i can get a catalytic converter.
Results 1 to 2 of 2
  1. #1 I need to no were i can get a catalytic converter.
    houston
    I need to install a new catalytic converter, is there any ya recommend that is good and cheap besides the stock one from the dealer??? i dont want one from the dealer cuz they expensive as hell, but i was looking at that webside zzperformance and they have them but i want to no also if they are anygood?? and like what would i need to get if i do get it since it has like option 1 and option 2. Oh and if it would better getting a 2 1/2 inch or 3inch?? my car is stock so idk if it comes with a 2 1/2 inch or 3inch. ok well let me no ya need some more info, and what ya recommend. any websites that i can look at. and like do i need to buy anything else besides the cat or will it fit it just perfect with the stock one??
  2. #2 Re: I need to no were i can get a catalytic converter.
    Jersey
    I have a zzp one, i like it.
    get the 2.5" bolt in (it will be easier to install) going 3" is pointless since its going right into your stock cat-back. Going cat-less is up to you, it will smell like gas if you go that route. You will need upper and lower DP gaskets, installation is easy (4 bolts) just use plenty of WD-40 because they will be rusted.
    16' wrx sti- stock
  1. I need to no were i can get a catalytic converter.
    By krazyog1 in forum 04+ Specifics
    Last Post: 10-06-2009, 03:53 PM
  2. choppin out catalytic converter
    By gtpinsc in forum General Tech Discussion
    Last Post: 12-31-2008, 01:18 PM
  3. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
  4. Catalytic Converter Theft
    Last Post: 02-24-2008, 09:49 PM
