Thread: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    St. Louis
    I looked for a piston for my 00 GPGT when I grenaded the original motor. Best I could find was $225. This doesn't account for the machine work to the rest of the motor to make it survive. Replaced the entire motor with one that had 150K on it and still going at 317K. Don't waste your money on trying to save this one. Just get a long block or complete motor from the JY and go from there.
    You can rent an engine hoist for a weekend and still come out way ahead.
  2. #22 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    its a long shot that swapping one piston will last, some have done it and the engine was just fine, others have not had such good luck.
  3. #23 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    Morad Parts Company.
  4. #24 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    What typically happens?
    What if I swapped all 6?
  5. #25 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I believe they call it the 300 mile motor.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  6. #26 Re: Multifaceted Question/Situation (Oil Pan Gasket, Shift-Kit, False Knock, et. al)
    Quote Originally Posted by bsharpminor View Post
    with out a machine shop or at least checking the bearing clearances? boom in 200 miles maybe, or maybe it lasts 30,000 miles, hard to say.
    what ever you do dont unbolt the crank.
    in the end a used whole engine, even if its n/a and you use your old engine to top swap it will be cheaper and more reliable in the long run.
  1. False knock causing p0327?
    By outonthetiles in forum General Tech Discussion
    Last Post: 05-18-2012, 03:16 PM
  2. False knock??
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2011, 04:43 PM
  3. False Knock?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2011, 11:14 PM
  4. false knock?
    Last Post: 08-20-2009, 09:21 PM
  5. new gasket less knock...?
    Last Post: 08-20-2009, 10:04 AM
