Thread: Small pulley and inter cooling
Results 1 to 12 of 12
  1. #1 Small pulley and inter cooling
    GT Level Member rolyat's Avatar
    OKC
    I was just curious what some of y'alls opinion would be on going with a 2.8" pulley with the mods in my sig plus a phenolic intercooler. I would get a conservative tune with it. I am NOT looking to make the most power I can just so I wouldn't trash my trans too much. It is rebuilt, but not beefed up unfortunately. Honestly I am just looking to get a little more power and that awesome s/c whine!
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  2. #2 Re: Small pulley and inter cooling
    GTP Level Member
    Sep 2011
    Motown
    Clear PM Box
    Thanks!
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  3. #3 Re: Small pulley and inter cooling
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    ooo be careful man. do you have access to e85?
  4. #4 Re: Small pulley and inter cooling
    2.8 probably is a no go. 3.0-3.2 is more like it.
  5. #5 Re: Small pulley and inter cooling
    GTP Level Member tms8582's Avatar
    Washington Michigan
    if your getting a dyno tune bring a few pullies and the appropriate belts with you and see how small you can go without kr. im running a 2.8 with e85 fuel and no intercooler.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  6. #6 Re: Small pulley and inter cooling
    3.2"~?
    Depends if the phenolic is full size or not too.
    Maybe a 3.0" with stock~ish timing.
  7. #7 Re: Small pulley and inter cooling
    Feb 2013
    37.295091, -121.930053
    final word on it
    MOTOR GO BOOM!!!
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: Small pulley and inter cooling
    OKC
    Well I know I could get a 3.2 safely with a full sized intercooler. I will probably go with a 3" if and find a way to safely plug up those ports...
  9. #9 Re: Small pulley and inter cooling
    Washington Michigan
    After all your mods are done and you pulley down just make sure you scan for kr. FYI I ran a 3.2 with 93 reg gas and a 2.8 on e85 on the same motor. E85 requires a high flow fuel pump, 60 lb. Injectors and a tune. Probably less money than an intercooler.
  10. #10 Re: Small pulley and inter cooling
    OKC
    Yea e85 would be nice, but just too inconvenient since it is my daily driver and there aren't many stations around here with it. I also don't have a cam like you. Just 1.9 rockers. If I had a big cam I wouldn't even be worried about running a 2.8
  11. #11 Re: Small pulley and inter cooling
    GTP Level Member AjL227's Avatar
    IL
    I'll recommend you pulley down slowly, and not take huge steps at once.
    I have three stations all within close proximity of my house distributing E85...
    I filled up a week ago from Speedway for $2.44/gal ! I am rather pleased with the recent price drop.
    A Mobil station less than 5 miles away charges $3.39/gal, however I'm going to Speedway from now on.
    Car is my daily. 80# Mototrons, stock pump w/ Racetronix rewire
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  12. #12 Re: Small pulley and inter cooling
    Washington Michigan
    Quote Originally Posted by AjL227 View Post
    Yeah e85 is the way to go with charged motors for sure however access to fuel is key. Meijer sells e85 in Michigan so it's just about everywhere in the Detroit Metro area. Speedway doesn't offer it here but $2.44 is sweet!
  1. What size pulley is "TO SMALL"????
    By kenizzle36 in forum General Tech Discussion
    Last Post: 08-20-2011, 04:10 AM
  2. PCM model year inter-changing?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2010, 06:16 PM
  3. Inter. Fan motor runs w/out key
    By srspicer in forum General Tech Discussion
    Last Post: 06-27-2010, 02:29 AM
  4. New small appearance mod..
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 03-31-2009, 11:49 PM
