Thread: Few issues I'd like to fix
Results 1 to 12 of 12
  1. #1 Few issues I'd like to fix
    Donating Users
    Aug 2013
    Michigan, USA
    I just got a 2005 GP and it did have a few minor issues.
    First, it got the classic blower that won't blow problem. Easy fix, just got to wait for the part to show up.
    Second, the key FOB does not work. I replaced the battery and checked that the clip is firmly soldered on (why are those clips easy to break?) but it still won't lock/unlock, open trunk, or panic at all. Is there a way to tell if it's working and needs to be reset or if I need to replace the whole thing?
    Third: the LCD on the radio/CD player is very hard to read. It looks like maybe the LED backlighting either got loose and isn't getting power or the LED burned out. Can that be fixed? I have 20 years electronics experience, just prefer not to spend a lot of time taking it apart if it's not easy.
    Fourth: a piece seems to be missing from the console under the key slot and next to volume knob:
    http://i256.photobucket.com/albums/h...ps0f9bd507.jpg
    What is it? So that I can look it up and get it to cover the unsightly holes.
    And lastly, I'd need manual for this car. Is there a PDF I can download somewhere? I tried Google and keep getting web site that wants to charge an arm and a leg just to view it Or is the manual not free? I need the manual to find out what else needs to be checked like the fuses, where are the important parts, etc.
    The other LCD display is showing today is Thursday, Jan 6 so I need to change it (hence the manual request), the cruise control will not work at all (bad fuse? again need manual) and I can't find jack should I need to change tire.
    TIA for any answer you can provide.
  2. #2 Re: Few issues I'd like to fix
    Aug 2011
    'Merica
    you will need to have the dealer program the fob
    there is a write up on how to replace the bulbs in the display
    http://www.grandprixforums.net/04-gp...fix-34355.html
    I am missing that piece too
    does your car have a 3 button dic or 5 button?
  3. #3 Re: Few issues I'd like to fix
    Donating Users
    Aug 2013
    Michigan, USA
    Thanks for the link!
    Quote Originally Posted by Below Average Joe View Post
    3 buttons if that's the top LCD that shows odometer, date, and warnings. What does DIC stand for anyway?
    Going to look in the bulb replacement guide so I can see what I need to get.
  4. #4 Re: Few issues I'd like to fix
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    It stands for Driver Information Center.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  5. #5 Re: Few issues I'd like to fix
    one owners manual.....http://www.vadengmpp.com/owners-manu...-GrandPrix.pdf yeah they are out there for free.
  6. #6 Re: Few issues I'd like to fix
    Donating Users
    Aug 2013
    Michigan, USA
    Got the date set correctly. Still can't get the key fob to work so I may need to have it reprogrammed. I need a replacement key anyway since the dealer had only 1 and I'd prefer to have a spare in case I get locked out.
  7. #7 Re: Few issues I'd like to fix
    GTP Level Member simbah's Avatar
    Lala land
    Be prepared to spend some money. A key and fob programmed can run over $100.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  8. #8 Re: Few issues I'd like to fix
    Jul 2013
    Richmond, VA
    The missing part on your dash is a little textured pad. I can only guess its purpose is to keep your keys from making a bunch of noise when swinging back and forth and hitting the dash while in motion.
    Key fob can be programmed by anyone with a tech2 scanner. The dealer had a locksmith do mine. Also I think you can program a spare key if you have the master. Quick search retrieved this:
    Put the programmed key into the ignition turn to ON, take key out and put second key in immediately and turn to ON.
  9. #9 Re: Few issues I'd like to fix
    Donating Users
    Aug 2013
    Michigan, USA
    I can probably trim a piece of thin black foam and hot glue it in place.
    I found another issue with my car, the cig lighter sockets (both) do not work. I already checked the fuse, assuming it's the one under the hood, slot #10 (ACC), 25A it is good so is that the right fuse for the lighter socket or is there another? Or do I need to assume the wiring has come loose inside the console and not powering the sockets?
  10. #10 Re: Few issues I'd like to fix
    Aug 2011
    'Merica
    The piece that is missing is this GM# 15238632 - List $7.29
    If you have any questions about part numbers that you can't seem to find, PM TLSheff, he works at a dealership in the service department.
  11. #11 Re: Few issues I'd like to fix
    Pennsylvania, USA
    Your key fob is most likely fine, the conductive pads may have just worn off under the buttons like they commonly do.
    Try this, pop open your key fob and find the little black dots attached to the rubber buttons. Take some aluminum foil and cut or tear a couple squares out that will cover those black dots without going out of the button shapes. Then just super glue the squares over those dots, let it dry, and throw it back together.
    It may fix your problem, but even if not it's a good idea for these GM key fobs. Those conductive dots always wear out and cause problems. I used to have to squeeze the buttons so damn hard for them to work, now a light push works every time.
  12. #12 Re: Few issues I'd like to fix
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Quote Originally Posted by nik12937 View Post
    If the foil works then as mentioned, the conductive dots is wore out. Since I not sure which FOB you have, I have used both of these. My 06 GP has remote start and this is what worked:New Buick Pontiac Chevy Replacement Keyless Remote Case Button Pad Repair | eBay
    My Granddaughter 06 GP did not have the remote start button and this one fit hers: New Buick Pontiac Chevy Replacement Button Pad Keyless Entry Key Remote Fob Fix | eBay
    There is also a fix for an insert that has the foil on clear plastic bubbles that works on both. Lot of people just super glue a small piece of foil on the rubber pad. Both of the eBay ones worked, the one with remote start is real easy to push and sometimes while holding it in my hand I accidentally set off the alarm. Good news for the neighbors, I don't do bars anymore, bad news is I go to work at 5:30am in the morning. :-) The model for the grand daughter, she has not said good or bad.
    I too had the dim radio controls. I found a source on eBay that has 20 of the clear bulbs for about $8 shipped. They are coming from China, so it will be awhile before I know how they work.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  1. kr issues
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2013, 08:03 PM
  2. New here and having some issues
    By bmed10 in forum Introductions/Noob Questions
    Last Post: 09-19-2012, 12:44 AM
  3. MAF issues?
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 07-18-2011, 05:40 PM
  4. Any issues?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 12-27-2009, 06:42 PM
  5. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
