Thread: kr issues
Results 1 to 19 of 19
  1. #1 kr issues
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    ok so heres the deal, ive got lots of kr...up to 15 degrees but only under 3k above that and i have 0 all the way to 100mph, then it comes back at around 6 to 8.
    Mods
    -gen v on 3.4 mps
    -headers
    -1.8 slp rockers valve springs from ls2
    -custom tune(supposedly it can be alot better)
    -northstar tb and LS maf may be the other way around cant remember
    -aeroforce interceptor, and boost guage
    If you are looking at the engine from the front I checked the middle and right piston with a borescope, and they looked good, i didnt have time to check the rest and i read these are the first to chip.
    changed spark plugs and fuel filter ran seafoam in the gas
    another thing i found odd was my boost the highest ive seen it was 13.5 lbs but normally around 12 i know this cant be correct on a 3.4 unless my charger is in beast mode or something lol correct me if im wrong but shouldnt it be llike 10lbs
    -PLANS
    im goning to take it to prj if for retune and putting a meth kit on it
    i ordered a 3.5 mps for the time being
  2. #2 Re: kr issues
    Gen V is better than a Gen 3, hence why the boost is alot higher.
    That 3.4 is like a 3.2 on a gen 3.
  3. #3 Re: kr issues
    Slower, Lower Delaware
    I/C would solve a lot of your problems.
    Quote Originally Posted by jrb1027 View Post
    Mods
    -gen v on 3.4 mps
    -headers
    -PLANS
  4. #4 Re: kr issues
    Jun 2013
    brookville,IN
    Quote Originally Posted by Sudden View Post
    how about methanol
  5. #5 Re: kr issues
    Get a real tune before even thinking about ways to reduce KR.
    Up your pulley size and get it fixed.
    Because I bet after its straghtend out and if there is no internal damage the car will be running good and there will be no reason to buy a $1,000 dollar intercooler setup or spend money on a Meth kit.
    This car just sounds like a complete hack job that needs to be fixed before even thinking about other mods.
  6. #6 Re: kr issues
    Jun 2013
    brookville,IN
    Ok Ive got a 3.5 on the way I just couldn't understand why kr would be so high under 3k rpm but zero kr the rest of the way up the power band, Also I figured if I got the meth kit now i could have my car tuned for it at the same time hence the tuner is far away from me and I work 7 days a week.
    But, I think I will take your suggestion I assumed this meth kit would help me out with the kr.
    Also do you have a suggestion for pulley size.
  7. #7 Re: kr issues
    Ohio
    This ^^^
  8. #8 Re: kr issues
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    If you have 15kr definitely go back to stock or youll get this
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  9. #9 Re: kr issues
    Nebraska
    get a 3" downpipe the ubend is restrictive and since you said your boost went from 12 to 13 maybe clogged cat, more boost more flow needed, if it cant get out fast enough its going to b high psi and high kr. The stock pcms have a part throttle problem with kr i see up to 5kr cruzing 0 to 1 WOT.
  10. #10 Re: kr issues
    Jun 2013
    brookville,IN
    Quote Originally Posted by 94GrandPrixSE View Post
    Yea ive got headers and no cat so not a problem there
  11. #11 Re: kr issues
    ^ he has headers
    04 Comp G.
  12. #12 Re: kr issues
    3.5 or 3.6 is better than a 3.4 as of right now.
    Meth can help with KR or as a power adder, but for you, you needed to get the car running good first before putting a bandaid mod on the problem.
    There must be something wrong with the data put into the PCM, you say its got a different TB and MAF, its very possible that thingys are wonky there and causing these problems.
  13. #13 Re: kr issues
    Jun 2013
    brookville,IN
    This seems very possible, I noticed today when I was driveing to work that my rail pressure only read 15 on my aero force, I didn't think I could read the pressure threw the guage is this correct
  14. #14 Re: kr issues
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Have you checked sources for false knock? Being that you aren't seeing any when you're over 3k maybe you've got a downpipe hitting or shot motor/trans mounts.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  15. #15 Re: kr issues
    Jun 2013
    brookville,IN
    Quote Originally Posted by JaredR215 View Post
    Yea I did take the pulley belt off and I found 0 kr
  16. #16 Re: kr issues
    AF can't read fuel pressue.
    The car wouldnt even run on 15 psi, needs 35-40 to just idle really, 45+ is the better
  17. #17 Re: kr issues
    Jun 2013
    brookville,IN
    That's what I thought so it must have been a phantom reading
  18. #18 Re: kr issues
    Jun 2013
    brookville,IN
    I figured i could give everyone an update, i got a tune from prj over the weekend and all the kr was false, had a cracked egr line. shes running pretty strong now, only problem is i havnt gotten any better than 15mpg since the tune cause i cant keep my foot out of it lol
  19. #19 Re: kr issues
    Yay!
    But
    If you want better MPG buy a Prius
    04 Comp G.
  1. 20's..any issues?
    By bziggy58 in forum Tires & Wheels
    Last Post: 05-10-2012, 04:51 PM
  2. One man, many issues
    By Chief Runs With Coyotes in forum Introductions/Noob Questions
    Last Post: 05-06-2012, 08:11 PM
  3. PCV issues......
    By RamairGTP2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 10:32 PM
  4. 04 GT 2 issues I need your help with...
    By skubasteve! in forum General Tech Discussion
    Last Post: 12-04-2009, 09:57 AM
  5. 05' gp gt issues!!!! - please help!!
    By Billyb in forum General Tech Discussion
    Last Post: 05-17-2009, 09:20 PM
