around 90lb of psi should keep it up and you just have to make sure your compressor is big enough. Also keep in mind that when you use a engine compression tester..you have to remove the schradar valve (might be calling it the wrong thing) so it allows the constant air pressure to keep the valve up.
Worse case scenario you can always just pull the head.
