Hey everyone,
My GTP has the digital climate control, but it is having a problem with the driver side blend door. I have pulled the actuator, tried it on the passenger side, and it works great. Just to see, I put the passenger side on the driver side, and it had the same behavior as the original. I disconnected the battery to perform the "relearn" of the actuators, and they both move fully like they should during the relearn. When I change the temperature on the driver side nothing happens, but the passenger side works flawlessly. I also go into diagnostic mode on the climate control and it is showing a system pass code (00 in the -00 menu). I'm pretty much at a loss as to what to check next, what would you guys recommend?
Thanks in advance.
