Thread: Windows, sunroof, radio don't work. Also needs a jump periodically??
Results 1 to 3 of 3
  1. #1 Windows, sunroof, radio don't work. Also needs a jump periodically??
    Aug 2013
    Wilmington, NC
    My windows, sunroof and radio don't work. I bought the car like this. What do I do? it's a 2001 grand prix gt. Fuses are good. It usually has to be jumped in the morning too. The battery, alternator and starter are good says advanced auto. He said it's probably lose wiring somewhere. Any suggestions?? The a/c also doesn't blow cold air. I think I recharged it right but not sure. My skill level is beginner. THANKS!
  2. #2 Re: Windows, sunroof, radio don't work. Also needs a jump periodically??
    Dec 2012
    Where 4T65E's were born
    Well those kinds of problems are ones you will have to do some diagnosing of your own. If all fuses are good, at least check for voltage at a window motor switch. Window motors go out somewhat commonly on GP's, and some people just leave them. I've seen people with up to 3 not working, and they don't care to replace them.
    If you get voltage at the switch, operate the switch, and make sure you get that same voltage on the output side. Sometimes the switches get carbon on them and stop conducting. If you get voltage, the motor is likely bad. So when you go in there, apply 12v manually is you want to be 100% sure.
    If not, you will need to make sure there is power making it out of the fuse(both fuse boxes), and check the wiring going to the switches.
    Same with the radio, check for power going out of the fuse, and check the wiring going to it.
    Sold.
  3. #3 Re: Windows, sunroof, radio don't work. Also needs a jump periodically??
    St. Louis
    I'd start by checking all your battery cables and grounds under the hood. Be sure they are clean and tight. A loose ground can cause all sorts of wierd issues.
    Did you check the fuses under the hood AND on the inside of the car?
    Have the A/C charged by a shop. If need be, have them test it for leaks first and then if it holds have them charge it back up. Not something you want to mess with yourself.
  1. Windows don't work
    By r803 in forum General Tech Discussion
    Last Post: 06-22-2012, 03:51 PM
  2. Windows work only when raining
    By aminkel in forum General Tech Discussion
    Last Post: 06-14-2011, 04:35 PM
  3. Radio,Sunroof,windows dont work
    By My GTP 97 in forum Audio, Security & Visual Electronics
    Last Post: 02-26-2010, 07:40 PM
  4. Windows and radio will not work
    By PatrolmanA16 in forum General Tech Discussion
    Last Post: 09-21-2009, 07:11 AM
  5. door chime/windows/sunroof/radio
    By shawn3091 in forum General Tech Discussion
    Last Post: 02-02-2009, 06:42 PM
