Thread: Surging when shifting from second gear
Results 1 to 6 of 6
  1. #1 Surging when shifting from second gear
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I've got an rpm surge when my car shifts from second gear (35mph or so). It shifts fine on the other gears and while boosting. Could it be my TC locking? I also just changed spark plugs and I read on a different forum that a guy had a misfire and he took off the plug wire heat shields and somehow that fixed his misfire. I was thinking about doing the same. Is this safe, and do they just slide off? Also when going to remove my O2 sensor for the back plug, I had to spray PB to break the sensor loose so I'm wondering if some of that got in between the wire and plug and caused this? Any help would be appreciated like always.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Surging when shifting from second gear
    Apr 2013
    Milwaukee
    I'm thinking plug wires?
    Sent from my PantechP8010 using Tapatalk
  3. #3 Re: Surging when shifting from second gear
    the plug wires should always be changed with the plugs. those heat shields, toss them in the trash.
    and what plugs did you put in?
    was this problem there before the plug change?
    your the first one ive ever heard of that took out the o2 to get the spark plug out. thats a new one by me. theres no need for that.
  4. #4 Re: Surging when shifting from second gear
    Apr 2013
    Milwaukee
    I had to take out the o2 because I'm dumb and forgot I could rock the engine forward. I put it autolite 605's gapped to about 0.52. The problem started after the plug change.
  5. #5 Re: Surging when shifting from second gear
    my bet would be on a plug wire being toast/pulled apart.
    get some local auto parts store brand plug wires. they work just fine.
    switch the plug wire thats got the mis with the wire next to it. if the mis moves its the wire.
  6. #6 Re: Surging when shifting from second gear
    Apr 2013
    Milwaukee
    How would I know which one has the mis?
  1. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  2. Transmission not shifting into top gear.
    By sseilmnop in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-05-2012, 07:47 AM
  3. 04 GTP Comp G Shifting Hard from 1st to second gear
    By 850Fishing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2012, 01:54 PM
  4. Surging... shifting issues??
    By tayl5645 in forum General Tech Discussion
    Last Post: 01-05-2011, 02:03 PM
  5. Transmission shifting from 3rd to 4th gear
    By tbrereto in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2010, 01:02 PM
