Thread: !Rear turn signal But no Tail Light!
Results 1 to 7 of 7
  1. #1 !Rear turn signal But no Tail Light!
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    My passenger side rear turn signal works perfectly fine(new bulb) but the tail light that is supposed to be the same bulb will not illuminate when its time for the lights to be on. Anyone know why this might be? I have a repair order from an officer, so i really need it done. Ive tried turning the switch inside that doesnt work, and when it turns night time and they automatically come on it still wont come on but it will still blink for the signal. HELP PLEASE!
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: !Rear turn signal But no Tail Light!
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    Does the Left taillight and center taillight work? Do you have a multi-meter? check the connections with a friend, pull the bulb out and test for 12v at the connector. if no current shows while depressing the brakes then you must search for the short.
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  3. #3 Re: !Rear turn signal But no Tail Light!
    New Carrollton,MD
    Yes the left tail light is and brake light in window is fine. Its only the tail light, turn signal which goes through the same bulb is fine, its just my tail, parking is fine also.
  4. #4 Re: !Rear turn signal But no Tail Light!
    May 2013
    I would for on swap the bulbs from L 2 R and see if it follows and if not start searching for the short, most likely the within the socket or the wires to the socket.
  5. #5 Re: !Rear turn signal But no Tail Light!
    sounds like a bad socket. id poke it with a test light see if it lights up.
    a lot of these bulb sockets un clip off the wires. if it does take it off, test for power at the plug. ive had sockets go bad. its a easy change even if you need to cut it off and solder on a new socket.
    with the moisture problem in the GP's tail lights have id be thinking socket.
  6. #6 Re: !Rear turn signal But no Tail Light!
    New Carrollton,MD
    I went and took a water vinager mixture with a Q-Tip and cleaned out the socket and now it works. Thanks for all the help.
  7. #7 Re: !Rear turn signal But no Tail Light!
    just in time for court too. glad its all working again.
    do they dismiss those tickets if you show its fixed?
  1. Brake light and turn signal issue
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-13-2014, 01:21 PM
  2. no right brakel light/turn signal
    By jjlw in forum General Tech Discussion
    Last Post: 04-01-2013, 11:09 PM
  3. 08 turn-signal & brake light issue
    By Dee Johnson in forum General Grand Prix Discussion
    Last Post: 10-03-2012, 02:22 PM
  4. Right Rear Turn Signal Out But Light Is Still On?
    By Joseph27705 in forum General Tech Discussion
    Last Post: 06-28-2012, 06:01 PM
