Thread: Elec issues
Results 1 to 17 of 17
  1. #1 Elec issues
    May 2013
    Tacoma, WA
    Ok this one just started about a week ago. After I start my engine some time my dash, A/C and radio would go off for a sec and the back on but the engine stays running. This might happen 1 or 2 time then that’s it. It has happened in the morning and in the afternoon. I have wiggled the ignition key to see if it might be the issue but nothing happens. The other issue is yesterday I was in the parking lot and I put the Trans in neutral and revd the engine. I then noticed the MPH on the HUD went up also don’t know if the speedo does the same because it’s not working right nether. I did a search typing speedo and RPM but I can’t find anything. So any info would be great.
  2. #2 Re: Elec issues
    Feb 2013
    37.295091, -121.930053
    for the MPH on your hud going up thats a plug no connected I was able to force mine to that when I was changing the column and all it was a ground not pluged in. You may have to look at your grounds to see if they are clean and rust free.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Elec issues
    May 2013
    Tacoma, WA
    Which plug? The HUD plug?
  4. #4 Re: Elec issues
    Feb 2013
    yeah when i was fixing my column i had to unplug the column and 2 grounds that use a bolt from the column that hook up with a 13mm bolt. that bolt is connected to a magnesium plate but the grounds are steel and will rust sad part is that they are just about your break pedal behind the cover.
  5. #5 Re: Elec issues
    May 2013
    Tacoma, WA
    Cool thanks now I have a weekend project
  6. #6 Re: Elec issues
    May 2013
    Tacoma, WA
    Would that cause to skip as the MPH go up too?
  7. #7 Re: Elec issues
    Feb 2013
    Are you talking about on the HUD? or the speedo?
  8. #8 Re: Elec issues
    May 2013
    Tacoma, WA
    Had to type fast boss was walking by and i skipped a word lol. Yea that question was about the speedo now. As I drive the speedo skipps.
  9. #9 Re: Elec issues
    Feb 2013
    first off it could be the speed sensor in the tranny that is causing that buy giving a false pulse count. or it could be your cluster is worn out. i would try the sensor because its cheaper and just a few mins of your time lol.
  10. #10 Re: Elec issues
    May 2013
    Tacoma, WA
    Ok before i could check my connection I noticed it would only happen when I would turn my AC on to the setting 1-4 but when I turned it to 5 everything came back on. So Im lost now.... Ill try and get a video today for better understanding of the issue.
  11. #11 Re: Elec issues
    May 2013
    Tacoma, WA
    Bump. Anyone?
  12. #12 Re: Elec issues
    The ignition key on these isn't as directly connected as it seems... It sounds like the power in the switch is starting to fail.
  13. #13 Re: Elec issues
    May 2013
    Tacoma, WA
    So what could be the solution?
  14. #14 Re: Elec issues
    Unfortunately it's very tough to diagnose these at times. BackinBlack did a great write up on bypassing the ignition switch for power on CGP. Since it's fairly straight forward and only requires a relay and some time, it might be a good first step to try and diagnose.
  15. #15 Re: Elec issues
    May 2013
    Tacoma, WA
    Sweet thanks ill look it up thanks for the help.
  16. #16 Re: Elec issues
    May 2013
    Tacoma, WA
    It's there a control box that send power to the A/C, heated seats and the boost gage?
  17. #17 Re: Elec issues
    May 2013
    Tacoma, WA
    Anyone?!?!
  1. WTB Elec water pump and any aftermarket DP (2.5/3.0 cattless prefered)
    By darkhorizon in forum Wanted To Buy - Parts
    Last Post: 05-12-2013, 09:56 AM
  2. Battery dead, AGAIN. ABS light on + other elec issues
    By The Chad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2013, 08:10 PM
  3. Battery dead, AGAIN. ABS light on + other elec issues
    By The Chad in forum General Tech Discussion
    Last Post: 02-26-2013, 11:00 AM
  4. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
