yeah when i was fixing my column i had to unplug the column and 2 grounds that use a bolt from the column that hook up with a 13mm bolt. that bolt is connected to a magnesium plate but the grounds are steel and will rust sad part is that they are just about your break pedal behind the cover.
Would that cause to skip as the MPH go up too?
