Thread: Will this supercharger work on my 03 GTP?
Results 1 to 12 of 12
  1. #1 Will this supercharger work on my 03 GTP?
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    I am wondering if it is worthwhile, a good idea, a bad idea, won't work, will take alot of work, etc. for the supercharger at the following link, to put on my GTP?
    GM Pontiac Buick 3.8L 3800 Eaton M62 Supercharger - Brandon, Manitoba Classifieds
    I only ask this, as I could spend my days polishing this one, while not having my car down during the polishing.
  2. #2 Re: Will this supercharger work on my 03 GTP?
    no, its from a series I.
    SII+ parts will work though.
  3. #3 Re: Will this supercharger work on my 03 GTP?
    Max Cook
    Guest
    lol I like how the last picture is a genV supercharger (completely different). Dont buy that supercharger, its garbage. Get a Gen3 or a genV if you want one for a spare. theyre not even that expensive.
  4. #4 Re: Will this supercharger work on my 03 GTP?
    Mar 2013
    Manitoba, Canada
    How difficult would it be to take my internals and put them into another case? I was thinking getting a wrecker special supercharger, polish that baby up, then put my internals into it? Of course it would be a good time for new seals, gaskets, coupler, and what not.
  5. #5 Re: Will this supercharger work on my 03 GTP?
    Banned
    Jan 2013
    Colorado
    the m62 is for the 4 bangers like a cobalt
  6. #6 Re: Will this supercharger work on my 03 GTP?
    Banned
    Jan 2013
    Colorado
    very and a lot more expensive than just getting another blower
  7. #7 Re: Will this supercharger work on my 03 GTP?
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by camopaint0707 View Post
    Why would it be very difficult? If I were to buy a salvage yard blower, how would I tell if it is in good shape, or on its last leg? I understand the obvious bearing wear which is easy to detect, but how do I tell if the rotors are worn, or if it will build normal pressure? Yes, I know that the supercharger just moves air and doesn't actually compress it, but you get what I mean.
  8. #8 Re: Will this supercharger work on my 03 GTP?
    The Boss Iceman6669's Avatar
    Jun 2011
    ??? It is easy to throw your rotor pack and snout on/in a new case...
    2011 F-150 Yote powered
  9. #9 Re: Will this supercharger work on my 03 GTP?
    A lot of guys here have Gen 3's we'd sell cheap.
  10. #10 Re: Will this supercharger work on my 03 GTP?
    That M62 from the early 90's was found on the series I 3800 engines.
    The cost is exactly the same or less. If you buy just a case, that's cheaper than buying a complete unit. Just use some sealant and call it a day.
    Apparently, the cases wear in with the rotors pack and should never be mismatched. But at this point, it won't matter.
    The issue with cost arises when you want to replace the seals and bearings. Rebuilding the snout requires a press, but can be done with basic tools. The rotor pack bearings are essentially non-serviceable. There's a thread on here about that, and solutions for replacing them short of buying a new rotor pack.
    Alternatively, you could keep buying used blowers with decent rotor coatings and just keep using them.
    The most expensive option would be either a rebuilt unit from ZZP which comes with a new rotor pack. Also consider a gen V swap, if only for the better rotor coating and case.
    A bad rotor coating will chip and be very shiny. The colour of the rotor coating before carbon buildup is a light grey.
  11. #11 Re: Will this supercharger work on my 03 GTP?
    Mar 2013
    Manitoba, Canada
    Lots of good info. Thanks. How much work is it to swap a Gen V onto my '03 GTP? (If there is a how to, just refer me to that instead of describing the procedure.
    And lastly, is it even possible to adapt an M112 blower to the 3800?
  12. #12 Re: Will this supercharger work on my 03 GTP?
    M112 is pointless unless you're way out there in power, even then, some argue it's still pointless. Way out there being over 350 WHP. Reason being, the gen V m90 housing and a spacer is how it's fitted. So it's far from ideal.
    Biggest cost associated with gen V is the blower itself. Last time I looked they were around 300 for a stock one, and a little more with an MPS hub or different throttle body.
    If you want use the stock throttle body, you'll keep the costs down. I highly doubt the bigger throttle will help you any if you're near stock. If anything, just reduce the amount of usable pedal movement.
    http://www.grandprixforums.net/eaton...5-a-49039.html
  1. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  2. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  3. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  4. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  5. the stock supercharger belt will work on a 3.4 setup right?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2010, 11:36 AM
