Thread: Twin engine GTP project progress thread
Results 1 to 20 of 469
  1. #1 Re: Twin engine GTP project progress thread
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by Sandman View Post
    I like this
    What do you guys think about the side vent ?
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  2. #2 Re: Twin engine GTP project progress thread
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by TwinV6GTP View Post
    I barely noticed it at first. It is discreet, so I like.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by Bronco Boy View Post
    That's what I wanted.
    For the suspension question, I'm using stock rear coil springs but they are preloaded. That means they are already compressed a good amount to increase initial spring rate.
    However one loses suspension travel which means limited rough terrain ability. but for a track car or even a friday night car it works.
  4. #4 Re: Twin engine GTP project progress thread
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Are the "stock rear springs" variable rate? Otherwise preload should not change the spring rate. I am not denying the effect (slowing weight transfer to the rear), just not seeing the physic yet. Be patient to the newbie. :-)
    I found this web site http://www.zoomsquared.com/technical...#comment-11266 It had a pretty good explantion of what I was trying to ask, but still I did not see it totaly. Here was my question to him....
    Something I am missing here. To compress the spring to 400lb/in of preload and the system is static or balanced, then as you said the spring pushing up with 400lb but the ring has to be pushing down with 400lb. Then when you add 938lb to the system is not the total weight now 1328lb? I know my thinking has to be flawed, it just been a while since my physic. And it was physic I at that :-). My only way of seeing this is some sort of potential energy cause by the preload, but my poor mind is not seeing it yet.
    I asked the question to author and I am waiting on a reply.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  5. #5 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by penright View Post
    A Spring when at rest has a certain tension and can support X amount of weight before noticeable compression happens.
    When you pre-compress it, the weight needed to compress it more is higher. The stock rear springs at rest can barely handle the weight of a lunch box in the trunk without dropping lol.
    When compressing them in advance via a pre-load device then the initial rate of the spring is now higher because it starts with tighter coils. But you lose suspension travel.
    Right now a 200lbs guy has a hard time even making the rear end drop even a little while jumping in the trunk.
  1. Replies: 164
    Last Post: 10-03-2015, 09:07 PM
  2. Replies: 89
    Last Post: 11-20-2012, 11:30 AM
  3. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  4. my progress thread
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 07-06-2011, 01:26 AM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
