Quote Originally Posted by Turbocharged400sbc View Post
fYI you can install front springs onto rear struts.
Works good
Thanks for tip, If I ever need more then I know that's an option.
I have all the preload/stiffness and height I need for now.
because I'm using front knuckles, the springs have to compress to even bolt. I made an adjustable height adapter. I can have lots of wheel gap and normal suspension or super stiff and perfect ride height.
Front springs with rear struts + front knuckles would give me too much spring rate.
