We worked on it 2 hours today we took out the rack and pinion and cut the shaft going into the rack and pinion so we have a full assembly with outer, inner tie rod and shaft (to be welded). Our tie rod support will be where the rack and pinion used to sit and will be stronger, camber and toe will be ajustable.
The struts hole will be slotted and the knuckles slightly modified.
Pictures to come.
