Thread: Twin engine GTP project progress thread
Page 2 of 24 FirstFirst 123412 ... LastLast
Results 21 to 40 of 469
  1. #1 Re: Twin engine GTP project progress thread
    Omaha, NE
    This looks awesome! I can't wait to see the outcome. Take as many pics and vids as possible please!
  2. #2 Re: Twin engine GTP project progress thread
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Sub'd
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  3. #3 Re: Twin engine GTP project progress thread
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Dual A/C's are going to make it crazy cold. This project is going to be top 3 of all GP projects ever done.
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: Twin engine GTP project progress thread
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by Nighthwk12 View Post
    lol ! It should be a neat project for sure.
    We are removing the power steering pump/rack, going electric water pump, no alternator for the rear engine.
  5. #5 Re: Twin engine GTP project progress thread
    Crazy Canadians lol.
    04 Comp G.
  6. #6 Re: Twin engine GTP project progress thread
    oh man, do a 4 wheel steer job like a monster truck. lol id laugh my ass off if it did a 10 second 1/4 doing the crab lmao..
  7. #7 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Too much risk if anything goes wrong.
    But my plan is to go to the track and look like a FWD, just do a small burn out of the front tires then run a great time, surprise a few guys.
    Then my next burnout would be front tire first, then rear tire alone. Then we'll have a lot of looks lol
  8. #8 Re: Twin engine GTP project progress thread
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Just thinking out loud/quick thought, what issue would there be in mounting the second radiator up front. If you pop the hood it would not look stock. I wonder how big the lines would have to be and how much weight the water in the longer lines would add? Enough room? Enough air flow?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  9. #9 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by penright View Post
    Rad will be in the back for sure... two powerful fans on it. Should be enough to keep it cool. If it's not enough we'll go with very large size rad.
    That is something we'll have to test. The stock rad could be enough with a powerful electric water pump.
  10. #10 Re: Twin engine GTP project progress thread
    that would need 2 inch pipe ran from the front to the back. seen it done on off roar trucks with a rear engine, buggy's if you will. seem em use the roll cage as well to plumb the coolant.
  11. #11 Re: Twin engine GTP project progress thread
    Laurel, MD
    You probably wouldn't need to do a burnout at all.
  12. #12 Re: Twin engine GTP project progress thread
    Nov 2009
    Central Jersey
    Quote Originally Posted by ls1camino View Post
    This is true. I think he is going for the factor though with the burnouts
  13. #13 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Exactly...more for show than Go.
    But once I get serious with Timeslips, I will go with four e.t. street but the sleeper factor won't be there anymore and I will need a burnout then to get the most out of the MT tires.
  14. #14 Re: Twin engine GTP project progress thread
    May 2008
    Schuyler, NE
    Man, you guys do some cool stuff. Nice work on this. Can't wait to see what it runs.
  15. #15 Re: Twin engine GTP project progress thread
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by Sandman View Post
    Use the old gas door an an intake for the rear. Just put a small scoop there
    Excellent idea
    Yep, many of the off road buggys I run with have done this. It is more parts to deal with problems and such, but it is pretty common. I think trying to make a radiator work in the back is probably better, but it will have its own set of challenges.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  16. #16 Re: Twin engine GTP project progress thread
    Apr 2011
    Vassar, Mi
    When you go to do your burnout put one engine in reverse and one in forward and just smoke all four tires sitting still.....lol
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  17. #17 Re: Twin engine GTP project progress thread
    May 2013
    Gatineau
    Quote Originally Posted by Anthony Smith View Post
    I'll try that for sure !
    Today we worked on it a little. Boring stuff, trimmed more off the body to make it easier to work on the engine. Aligned every very close to how it will be. Decided on subframe heigth
    Decided on how to install subframe to the unibody so it is removable and very strong. Rear engine will have more traction so everything needs to be as strong as stock or stronger.
  18. #18 Re: Twin engine GTP project progress thread
    Nov 2011
    NY
    Sub'd
  19. #19 Re: Twin engine GTP project progress thread
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    For the air intake you could have the front of the trunk lid sit a few inches up or have like a heat extractor or something on the trunk lid
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  20. #20 Re: Twin engine GTP project progress thread
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    Sub'd
  1. Replies: 164
    Last Post: 10-03-2015, 09:07 PM
  2. Replies: 89
    Last Post: 11-20-2012, 11:30 AM
  3. push button start (progress thread)
    By z3r0 in forum Visual/Body Modifications
    Last Post: 12-01-2011, 08:38 PM
  4. my progress thread
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 07-06-2011, 01:26 AM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
