Thread: Strange rattle/knock
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Strange rattle/knock
    Dec 2012
    Where 4T65E's were born
    My car started running 5-10° hotter in the summer. I put a 180° in and it's running the same or 5° less. The middle mark is 200, which is just fine. Even the next mark is 210°, which is getting warm but still perfectly safe. It shouldn't get much past 210° because the fans will kick on.
    Sold.
  2. #22 Re: Strange rattle/knock
    SE Level Member BD3511's Avatar
    May 2012
    Sheffield Lake,Ohio
    Update everyone. Took it to my buddies place today to get a professional opinion on what could be the issue on this weird thump. He took it for a drive and then started to notice it and questioned what is that ? so we pulled it back into his shop and I sat in the car and held my foot on the brake with the car in drive and he checked everything and anything and couldn't hear anything. Can only be heard inside of the car it seems. My first question. Trans mount done ? loose bolt ? heat shield and SC coupler ? and he said no doesn't seem to be any of the above because if the SC coupler was bad we would hear it. And if the flex plate was done we would hear that as well especially when he was underneath the car. Any idea's ? And like I said this thumping only happens when In drive sitting at lights while the car is in Drive. Anything else it doesn't seem to make that noise.
    1998 Grand Prix 2D GTP-Silver**2002 Trans am WS6 6 speed**1988 Trans am 5.7 Turbo
    1988 Trans am GTA 5 speed-100% OEM
    1997 BMW M3
    2001 Ford F150 EXT- Towing/pulling/plowing
  3. #23 Re: Strange rattle/knock
    Howell, NJ
    Does it thump after you start moving from a stop.
  4. #24 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    yes it completely goes away once i start rolling it seems.
    1997 BMW M3
  5. #25 Re: Strange rattle/knock
    Dec 2012
    Hmm.. I think it's time to make a video on the problem.
    Sold.
  6. #26 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    To be honest I doubt A video would work well but I will try it in a little bit on the phone. And see if it picks it up
    Sent from my HTC6435LVW using Tapatalk 2
    1997 BMW M3
  7. #27 Re: Strange rattle/knock
    Dec 2012
    Can't hurt to try. Is it not loud enough for the mic to pick it up well enough or something?
    Sold.
  8. #28 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    not sure going to sure as hell try it's driving me nuts. I love my GTP and i'll sink whatever money i can into it to keep it running so i hate when something isn't right. Except the ABS and well that's another topic one day.
    1997 BMW M3
  9. #29 Re: Strange rattle/knock
    Howell, NJ
    Im pretty sure its one of your mounts. My old gp did what you are describing but I never looked into it.
    Try putting in reverse and accelerating. Mine would always make a thudding type noise as soon as I would begin to move.
  10. #30 Re: Strange rattle/knock
    pop the hood fire up the car, then watch the engine as you shift it from P to R then To D, and back R. if its flapping back and fourth you need new mounts for sure.
  11. #31 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    I'm going to check them Friday I did the main mount last year but neglected the trans I bet that's what's causing my issues. Because i remember how bad the thumping was with the motor mount and I guess it wouldn't hurt to swap out the dogbones as well
    1997 BMW M3
  12. #32 Re: Strange rattle/knock
    search flipping the dog bones. you flip the bushings in the rad support, tightens up the engine quite a bit.
  13. #33 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    I was going to just order poly mounts and I have read about that just haven't gotten around to doing it yet. Seems super easy to do
    1997 BMW M3
  14. #34 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    Think you guys are right on the mount. I think the trans mount is smashed from looking today. Because I recall when the main one went it would thump at lights and stop when I would take off. This thump isn't as bad but it's just annoying as hell. So i'm going to make a day out of this on Tuesday. Trans mount, dogbones, also found a vacuum leak as well which i'm going to replace that line as well. One thing I noticed yesterday thought that is driving me nuts which i'm going to probably have to go to another thread with this one is I let the car sit yesterday running when I got to work. I had some time so I let it run and it actually got hot to the point where for the first time ever I saw the TEMP light actually kick on. But when driving and when I got home yesterday I let it sit and it didn't heat up that much. Maybe someone could chime in that's viewing this thread ? Thermostat possibly shot ?
    1997 BMW M3
  15. #35 Re: Strange rattle/knock
    did the fans come on?
  16. #36 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    yeah I heard them.
    1997 BMW M3
  17. #37 Re: Strange rattle/knock
    make sure its full of coolant when it cools off, if its still full, id change the t stat.
  18. #38 Re: Strange rattle/knock
    May 2012
    Sheffield Lake,Ohio
    Coolant issue is fixed It was definitely low so I let it run for awhile and yeah temp issue under control lol. I had my girlfriend shift it from park to drive to reverse and back and the engine is definitely jumping again. Which i'm sure is the trans mount now. I guess I should have changed it when I did the motor mount. And for all I know the new motor mount could be faulty too.
    1997 BMW M3
  1. Low end rattle
    By kenconerly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2013, 12:03 PM
  2. 01 GTP Engine Rattle/Knock
    By Gizmo669 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 12:10 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Strange vibration/rattle... 02GTP
    By shredaspud in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 02:23 AM
  5. little bit of rattle and a tps?
    By gpgt04 in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2010, 07:47 PM
