Thread: Air Conditioning Problem
Results 1 to 10 of 10
Threaded View
rs2sensen Air Conditioning Problem 04-18-2011, 10:46 AM
whiney Re: Air Conditioning Low... 04-18-2011, 12:49 PM
FordMan77 Re: Air Conditioning Low... 04-18-2011, 01:17 PM
rs2sensen Re: Air Conditioning Low... 07-23-2011, 10:10 AM
dsmuts Re: Air Conditioning Problem 07-23-2011, 04:49 PM
rs2sensen Re: Air Conditioning Problem 07-23-2011, 11:11 PM
dsmuts Re: Air Conditioning Problem 07-24-2011, 09:52 AM
m0ni3l0v3 Re: Air Conditioning Problem 06-15-2013, 10:35 PM
dsmuts Re: Air Conditioning Problem 06-16-2013, 04:56 AM
BillBoost37 Re: Air Conditioning Problem 06-17-2013, 06:35 AM
  1. #1 Air Conditioning Problem
    Feb 2010
    Grand Rapids, MI
    I had my engine replaced about a year and a half ago when I discovered the previous owner had loaded the vehicle with stopleak after cracking the block. (Hey, it held for nearly 30k miles, not bad!)
    Prior to replacing the motor, my AC worked fine. Afterwards, it didn't work anymore. I'm guessing that the guys who did the work emptied it and didn't fill it up, or pinched a wire somewhere. I'm hoping for the former.
    Anyways... I noticed the AC clutch doesn't kick in at all, so I can't get it to suck in any extra coolant. What is the easiest way to bypass the low pressure switch so that I can fill the system up?
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. Air Conditioning Problem
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 12-04-2010, 06:06 PM
  3. Air conditioning problem...
    By RegorHtims in forum General Tech Discussion
    Last Post: 11-26-2010, 02:16 AM
  4. air conditioning
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 04:00 AM
  5. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
