Thread: Air Conditioning Problem
Results 1 to 10 of 10
Threaded View
  1. #6 Re: Air Conditioning Problem
    Feb 2010
    Grand Rapids, MI
    Thats what I thought too, but I've tried a new relay and that didn't do it. I'm going to test the relays I have with a multimeter tomorrow.
    Just to clarify, when I say jumpered, I mean that I used a paperclip to bridge the connections in the socket where the relay goes, not sure if I'm using the correct verbiage there or not.
    Thanks!
    EDIT: Actually... I just went and tried two more relays. No difference. I also stuck a new fuse in Fuse 28, which is labeled A/C CLU/ABS IGN on the schematic I have. No dice.
    Here's the schematic I was looking at:
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. Air Conditioning Problem
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 12-04-2010, 06:06 PM
  3. Air conditioning problem...
    By RegorHtims in forum General Tech Discussion
    Last Post: 11-26-2010, 02:16 AM
  4. air conditioning
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 04:00 AM
  5. vacuum pressure problem
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 11:47 AM
