Thread: Washer pump not working
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Washer pump not working
    And I bet your windshield is dirty too
    Fuse block under hood.. says it's a main ignition fuse 60amp.. it's good.
  2. #22 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    What does that have to do with my pump problem?
  3. #23 Re: Washer pump not working
    SE Level Member fromne's Avatar
    Nov 2012
    Omaha, NE
    Quote Originally Posted by coolone View Post
    Thanks Bill... Lol : )
    I used to say always that God helps those who help themselves... It took all of 10 seconds to google search "Grand Prix Fuse Block"
    2003 pontiac grand prix fuse box diagram - Fixya
    Geeeeeze...
    alright thanks. I searched for like half an hour and I came up with 3 sites that said there wasn't one. Didn't realize it was part of the wiper fuse
  4. #24 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    All the fuses are good. I have the wiring exposed and none are loose. I ran a wire from the pump to the inside of the car in order to essentially hot wire the car pump. However I can't figure out which wire is the signal wire to the pump to turn it on to splice into. This grey wire that I spliced into send a signal when you pull the mist switch which would work however it then sends a constant signal when you turn the wipers onto low or high mode so then it would be spraying fluid constantly. Any other idea what wire to tap into which is just for the pump.
  5. #25 Re: Washer pump not working
    you could run that wire to a push button switch. you just need to jump a fuse and hot wire from the fuse box to the other side of the switch.
  6. #26 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    Yeah but the problem is if I do that I'll just turn on the fluid but the wipers wouldn't move so I would still have to turn the knob on the stalk. I would rather try to fix this using the OEM switch.
  7. #27 Re: Washer pump not working
    Have you tried splicing into the washer wire? You said you tried the mist, yet we all know mist isn't how you actuate the pump. That's the wash button that's further down the stalk.
  8. #28 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    Not sure what you mean? I'm still looking in that mess of wires for the pump wire.
  9. #29 Re: Washer pump not working
    You don't have any schematics? I wouldn't try this w/o a schematic.
  10. #30 Re: Washer pump not working
  11. #31 Re: Washer pump not working
    I'm confused, you linked an ICM module schematic. I'm not seeing a pump in there anywhere.
  12. #32 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    The link I have is a full diagram of the washer and pump and wipers.
  13. #33 Re: Washer pump not working
  14. #34 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    Yeah it says dark green but I couldn't find it. I gave up and just hotwired my own push button.
  15. #35 Re: Washer pump not working
    What are you talking about dark green? Scott highlighted the exact wire for you. It's red.and goes into connector 2 of the underhood relay center at cavity F12, then it feeds the pump from Connector 3 cavity A12.
  16. #36 Re: Washer pump not working
    i cant take the credit for marking the diagram lol i found it like that lol
  17. #37 Re: Washer pump not working
    Good job posting it then..cause that's exactly what he needed......to realize he's colorblind.
  18. #38 Re: Washer pump not working
    Banned
    Jan 2013
    Colorado
    I know you know everything bill but I tried that wire and it didn't solve anything. The break in the connection occurs wherever that red wire connects to a harness somewhere under the dash.
  19. #39 Re: Washer pump not working
    I don't know everything..that's why I'm as good finding issues as I am. Everyday I can and do learn something new. That diagram though tells you what you need. You say you tested a green wire, yet the wire you were looking for ....wasn't green. I'm only joking a bit since you've got it fixed.
  1. Windshield Washer not working
    By trailshredder in forum General Tech Discussion
    Last Post: 01-30-2013, 04:48 PM
  2. washer fluid not working
    By 2000gtp8410 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 05:01 PM
  3. washer pump????
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-12-2010, 11:24 PM
  4. Windshield Washer not Working
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 06-02-2009, 06:08 PM
  5. Washer not working!
    By Dangerous313KidInAPrix in forum General Tech Discussion
    Last Post: 03-09-2009, 08:36 AM
