Quote Originally Posted by Adidasdude1989 View Post
Hey thanks, im also due for all mounts, i dont have a lower motor mount under my engine, when i had my sway bar replaced, the guy that did it should me the crushed up rubber and pulled it out an what not so now if i take right turns a little to fast, a little clunk is heard. Damn things are $50 from the auto part store, cheaper some where else maybe?
Are you saying you need a new lower mount or are you saying you don't have one? Your lower engine mount is located passenger side take the wheel off under the crank pulley you'll see whats left of the motor mount. Go to the store and opt for the solid rubber design (Sr) at the end of part number. There less prone to screwing up like the hydraulic mounts are. Make sire when you get the mounts shake them if you don't hear fluid moving inside you have the solid rubber.
