Thread: Clamp on a resonator?
Results 1 to 10 of 10
K Kraziee Clamp on a resonator? 05-28-2013, 07:29 AM
Grimsin Re: Clamp on a resonator? 05-28-2013, 07:33 AM
coolone Re: Clamp on a resonator? 05-28-2013, 07:49 AM
K Kraziee Re: Clamp on a resonator? 05-28-2013, 07:55 AM
K Kraziee Re: Clamp on a resonator? 05-28-2013, 07:53 AM
J GTP Re: Clamp on a resonator? 05-28-2013, 08:04 AM
K Kraziee Re: Clamp on a resonator? 05-28-2013, 08:11 AM
coolone Re: Clamp on a resonator? 05-28-2013, 12:41 PM
dbextreme Re: Clamp on a resonator? 05-28-2013, 09:39 PM
K Kraziee Re: Clamp on a resonator? 05-29-2013, 05:51 PM
  1. #1 Clamp on a resonator?
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Is it possible to hack off the resonator and just clamp a new one on instead of welding it?
  2. #2 Re: Clamp on a resonator?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    with good clamps, yup.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #3 Re: Clamp on a resonator?
    Nov 2011
    NY
    Yes, but you'll need the adapter to go to the flange. Stainless step clamps are what you want.
  4. #4 Re: Clamp on a resonator?
    Apr 2013
    Milwaukee
    Also, what is the adapter I would need? Thanks
  5. #5 Re: Clamp on a resonator?
    Apr 2013
    Milwaukee
    Nice, then I can do this by myself instead of paying a mechanic to weld it on.
  6. #6 Re: Clamp on a resonator?
    Apr 2009
    Maine
    If you haven't already bought it, don't waste your money on a factory replacement resonator. They are not the same as stock, but are exactly the same as a glasspack which will cost half as much or less.
  7. #7 Re: Clamp on a resonator?
    Apr 2013
    Milwaukee
    Ok, ya I havent bought it yet. Ik its not the best quality, but will this one bolt up with clamps? Yonaka New Universal Fit High Flow 2 5" Resonator Stainless Steel 22" Length | eBay
    It doesnt have a flange so idk how this could work..
  8. #8 Re: Clamp on a resonator?
    Nov 2011
    NY
    Go to Summit racing web site. They have a 30" resonator for like $30. You size the resonator to the pipe it's attaching to and the same for the flange. The GP has a 2 bolt flange...
    Crawl under there and measure and look at what you got, but yes, you can do it yourself.
  9. #9 Re: Clamp on a resonator?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Or just cut a couple inches behind your flange and use band clamps....
    BUT it might be worth your while to go to a muffler shop and get rid of the ubend if you have not already...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: Clamp on a resonator?
    Apr 2013
    Milwaukee
    Ok, I think I'll just cut before the flange then. So if I have the 3" zzp dp and it connects to my stock resonator which is I believe 2.25", do I get a 2.25" res or 2.5"?
  1. CV boot clamp breaks off...sits to low to frame
    By AREED in forum Brakes/Suspension/Chassis
    Last Post: 08-27-2013, 01:37 AM
  2. Radiator Hose Clamp Question
    By LeadfootCJ7 in forum General Tech Discussion
    Last Post: 02-20-2013, 03:20 PM
  3. band clamp and rvt ???
    By homerunhitter629 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2011, 09:07 AM
  4. Exhaust band clamp for speed daddy cross over
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 04:01 PM
  5. Exhaust clamp size (Speed Daddy headers)
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 07:06 PM
