Is it possible to hack off the resonator and just clamp a new one on instead of welding it?
with good clamps, yup.
Yes, but you'll need the adapter to go to the flange. Stainless step clamps are what you want.
If you haven't already bought it, don't waste your money on a factory replacement resonator. They are not the same as stock, but are exactly the same as a glasspack which will cost half as much or less.
Ok, ya I havent bought it yet. Ik its not the best quality, but will this one bolt up with clamps? Yonaka New Universal Fit High Flow 2 5" Resonator Stainless Steel 22" Length | eBay
It doesnt have a flange so idk how this could work..
Go to Summit racing web site. They have a 30" resonator for like $30. You size the resonator to the pipe it's attaching to and the same for the flange. The GP has a 2 bolt flange...
Crawl under there and measure and look at what you got, but yes, you can do it yourself.
Or just cut a couple inches behind your flange and use band clamps....
BUT it might be worth your while to go to a muffler shop and get rid of the ubend if you have not already...
Ok, I think I'll just cut before the flange then. So if I have the 3" zzp dp and it connects to my stock resonator which is I believe 2.25", do I get a 2.25" res or 2.5"?
