Thread: motor mounts
Results 1 to 20 of 22
  1. #1 motor mounts
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok im pretty sure my 00 grand prix is overdue for motor mounts, the rubber is cracked and broke off on the dog bones, ive searched and couldn't find were and if these cars have rear motor mounts,if so tell me were they are and also the trans mounts cause my cars motor jerks hard when going into reverse and I think they may be causing my vibration, my car has 198xxx miles on it and they have never been changed
  2. #2 Re: motor mounts
    Omaha, NE
    Under the engine and trans on the cradle.
  3. #3 Re: motor mounts
    you have a trans mount, and a motor mount, both located on the sub frame to the engine.
    the two top mounts, engine to the rad support are called "toque struts" or upper mounts.
    they all wear out.
    theres how to's here for all of them. quite easy really if you feel good about working on your car.
  4. #4 Re: motor mounts
    Jul 2010
    ok i can probably change them myself,cant be to bad,ive searched the forums and haven't fond a write up yet and is there a possibility it may be causing the vibration cause a motor shouldn't jerk back that hard,i think they are shot
  5. #5 Re: motor mounts
  6. #6 Re: motor mounts
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Hey thanks, im also due for all mounts, i dont have a lower motor mount under my engine, when i had my sway bar replaced, the guy that did it should me the crushed up rubber and pulled it out an what not so now if i take right turns a little to fast, a little clunk is heard. Damn things are $50 from the auto part store, cheaper some where else maybe?
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  7. #7 Re: motor mounts
    St. Louis
    Rockauto.com
  8. #8 Re: motor mounts
    Arizona
    Quote Originally Posted by Adidasdude1989 View Post
    Are you saying you need a new lower mount or are you saying you don't have one? Your lower engine mount is located passenger side take the wheel off under the crank pulley you'll see whats left of the motor mount. Go to the store and opt for the solid rubber design (Sr) at the end of part number. There less prone to screwing up like the hydraulic mounts are. Make sire when you get the mounts shake them if you don't hear fluid moving inside you have the solid rubber.
  9. #9 Re: motor mounts
    what a shot mount looks like,
    the rest of it.
    when this bad, you will see the engine try to rotate when you shift from P to R then to D. the pass side will move towards the rad, and then back to the firewall.
    oil leaks help kill the mount too.
  10. #10 Re: motor mounts
    Feb 2013
    37.295091, -121.930053
    scotty i had worse. but when it gets that bad yeah time for a new one if not then new motor time.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: motor mounts
    how does it get worse then that? its metal to metal no rubber left at all lol
    crazy part is is dint clunk, but the engine sure did move a lot. no vibrations or other issues.
    flipping the dog bones bushing makes the engine even tighter.
  12. #12 Re: motor mounts
    Not trying to jack the thread but does anyone still carry the solid mounts?
  13. #13 Re: motor mounts
    Arizona
    Quote Originally Posted by slick2500 View Post
    Auto one oriellys just have to specify solid rubber option
  14. #14 Re: motor mounts
    Feb 2013
    well i cleaned mine so it was smaller than your mount grease and oil do hide alot.
  15. #15 Re: motor mounts
    Quote Originally Posted by 91parkave View Post
    Okay sweet so Rockauto might still have them? Its just been a while since I looked.
  16. #16 Re: motor mounts
    Arizona
    I'd prefer a local auto store for the lifetime warranty
  17. #17 Re: motor mounts
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I Prefer ZZP's poly mount it may be twice as much but even the SR mounts have a hydraulic center and are prone to **** ups.
  18. #18 Re: motor mounts
    Arizona
    Quote Originally Posted by addzradd View Post
    Sure Zzp is a great option but solid rubber mounts are just that there is no fluid in them meaning they are not hydraulic in any way. Hydraulic mounts have fluid inside that allows for more movement in the mount for a comfortable compliant ride.
  19. #19 Re: motor mounts
    Banned
    Jan 2013
    Colorado
    is zzp the only company with poly mounts?
  20. #20 Re: motor mounts
    Feb 2010
    Cleveland
    Trust me even the "soild" mounts have fluid in them our NAPA SR mounts come back all the time for failures where they pop.
  1. 99 GP Oil Pan & motor mounts
    By schwarry in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2013, 12:06 PM
  2. Motor mounts
    By GTP GTP GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2012, 12:56 AM
  3. Motor Mounts
    By Classy Pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2012, 03:25 PM
  4. motor mounts
    By Chizzler in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2010, 08:10 AM
  5. top motor mounts
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 12:49 PM
