Not so fast. It doesn't just happen at/near the connector. It can happen ANYwhere along the entire harness. Yes, even under the factory electric tape wrapping. That's where the break in the wire that the previous owner repaired on mine was. I'd get a multimeter and check them before you completely rule out wires. If that checks out and it's not the wires, than it's most likely the brake solenoid behind the brake pedal.
