Thread: Please help. Why am I stuck in park?
Results 1 to 6 of 6
  1. #1 Please help. Why am I stuck in park?
    Mar 2012
    Pennsylvania
    So today my car decided that it wants to stay in park. I am able to release the shifter by pushing down on the shift lock release button but as soon as I throw it back in park it gets stuck. A year ago I had the key stuck in the ignition switch problem that some of you had but that was fixed by replacing ignition wires. So I'm clueless as to why the gear is stuck now.
    I have a 2001 grand prix GT. any help is greatly appreciated.
  2. #2 Re: Please help. Why am I stuck in park?
    SE Level Member 98 Grand Prix Gt's Avatar
    Jul 2010
    Wichita ks
    I had this issue, i fixed mine by going to a salvage yard and getting the wires that connect the shifter to the car itself, something is not connecting right as far as it sounds. the wires im talking about are underneath the shifter, should only cost like 10-20 bucks from a salvage yard for another
    Drive Fast....brake rarely...
  3. #3 Re: Please help. Why am I stuck in park?
    GT Level Member GRAFIX's Avatar
    Chicago, IL
    Locate the instrument fuse panel in the glove box. Check if the BTSI fuse is blown. I had the same problem.. it was due to a BTSI fuse blown.. If it's blown, under your hood in the main fuse box you should have spare 10amp fuses.. just take one and replace the BTSI fuse.
  4. #4 Re: Please help. Why am I stuck in park?
    Jan 2012
    Philadelphia
    i had this same problem on my 97 GTP and you know what i did.......... took off the shifter trim and pulled over that little white plastic piece in there that holds it and shove a small shim in there and it worked fine. only thing is you can move it in and out of park while the car is off, its still like that i didnt know how to properly fix it and i dont have a shift lock release.
  5. #5 Re: Please help. Why am I stuck in park?
    Chicago, IL
    I believe what you are referring to is the white solenoid. If so I would be concerned about that. If I were you I would test it to make sure it's not powered all the time. If it is it could drain your battery and possibly cause heat issues.
  6. #6 Re: Please help. Why am I stuck in park?
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    Shift lock solenoid is malfunctioning. It's behind the dash if I'm not mistaken, find one at a yard is your best bet.
  1. shfter stuck in park!
    By gtpeddie in forum General Tech Discussion
    Last Post: 03-21-2012, 10:06 AM
  2. Car won't move out of park and key stuck in ignition
    By kc199 in forum General Tech Discussion
    Last Post: 03-20-2012, 04:41 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  5. Stuck in park
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2010, 10:37 AM
