Thread: 3" DP to stock manifold
Results 1 to 17 of 17
  1. #1 3" DP to stock manifold
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Ik this has been asked a million times, but I want to be 100% sure before I buy. Does a 3" DP connect to the stock manifold? Ik they decrease to 2.5" at the other end to fit the resonator. Thanks for your input. BTW it's a pacesetter DP that came with there header's if that makes a difference.
  2. #2 Re: 3" DP to stock manifold
    Omaha, NE
    Yep. Bolts directly to the stock catback.
  3. #3 Re: 3" DP to stock manifold
    Portland Oregon
    I'm confused, are you going to try to use a downpipe from a set of headers to bolt to your stock manifolds? That won't work at all.
  4. #4 Re: 3" DP to stock manifold
    Omaha, NE
    After reading ^ and re reading the op I am also confused.
  5. #5 Re: 3" DP to stock manifold
    I was confused on the first reading.
  6. #6 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    The DP is from a set with pacsetter header's. I dont have the headers, just the downpipe. I can get a pic if you want.
  7. #7 Re: 3" DP to stock manifold
    No that downpipe will not connect to your stock rear exhaust manifold.
  8. #8 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    Ok thanks. Another quick question, if I buy Speed Daddy or equivalent header's, can i still use my stock cat?
  9. #9 Re: 3" DP to stock manifold
    You could if you put a bottleneck into the piping with a 3" to 2.25" reducer and then did other nonsense to enlarge it back to 3". Personally though, it's easier to get a 3" cat.
  10. #10 Re: 3" DP to stock manifold
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Yes, u will need a 3" pipe that reduces to 2.25" , im going to use my stock cat with my new SD headers
    Edit: bill beat me to it lol
  11. #11 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    Ok now one more question, I promise it's the last one. Will ZZP's 3" DP bolt to my stock manifold and resonator? The DP will be my first exhaust mod.
  12. #12 Re: 3" DP to stock manifold
    Yes..however they like to leak. So RTV the hell out of your new gasket to seal it up.
  13. #13 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    Okey dokey, is there a better DP you would suggest?
  14. #14 Re: 3" DP to stock manifold
    Quote Originally Posted by K Kraziee View Post
    I'm sorry.. no more questions!
    hahahahahaha
  15. #15 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    Ughhhh lol well il probly try the ZZP DP i guess.
  16. #16 Re: 3" DP to stock manifold
    You were the one that promised..lol
    I dunno of any better DP's.
  17. #17 Re: 3" DP to stock manifold
    Apr 2013
    Milwaukee
    Ik ik, I'l prob go for the ZZP. I should probly start pb'ing my bolts lol
  1. Went back to "stock" lookin tail lights...
    By TheYanz in forum Visual/Body Modifications
    Last Post: 07-26-2012, 01:29 AM
  2. stock manifold size ?
    By Derek81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2011, 02:17 PM
  3. will 3" downpipe fit on my stock manifold?
    By MOTELETJR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2010, 01:00 PM
