Thread: air charge temp sensor
Results 1 to 11 of 11
  1. #1 air charge temp sensor
    Jun 2012
    baltimore
    i have a check engine light and it seems the air charge temp sensor is the cause can someone tell me where this is located? thanks
  2. #2 Re: air charge temp sensor
    post the code, i have no idea what a charge temp sensor is.
    theres a ait sensor, air intake temp. its in the air filter tube from the air filter to the TB close to the TB.
  3. #3 Re: air charge temp sensor
    Jun 2012
    baltimore
    dont have the code off hand got it read at advanced. i got a delphi ts10072
    never changed one before all i know is it says air charge temp sensor.
  4. #4 Re: air charge temp sensor
    thats a iat sensor, its in the filter tube, has a wire leading to it.
    pull the plug off, then pull it straight up and out of the tube. you can try cleaning the old one. they get gummed up.
    also check the wires to the ait. they get messed up, i had to change that pigtail as well as the maf pig tail on my car.
  5. #5 Re: air charge temp sensor
    Jun 2012
    baltimore
    yup thats it. thanks for saving me from hunting for it. ill try cleaning it i guess if i put a new one on and it doesnt help i will check out the pig tail going to it. i will try and stay possitive. thanks for your help
  6. #6 Re: air charge temp sensor
    no problem. check the wires for missing insulation, once its gone the wires also die, they get whats called dry wire. then the wire dont pass current right.
  7. #7 Re: air charge temp sensor
    Jun 2012
    baltimore
    question the issue was the pigtail someone had replaced the iat before im guessing the wires were rubbing against metal and rubbed through. i went to the junk yard just to get a new pigtail same some time and money but mine says ped 10 the one i got is ped 11 will it make a difference it came off a 3800 series motor
  8. #8 Re: air charge temp sensor
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Here is a new harness for an 03 GT $22 locally in MN
    NAPA AUTO PARTS
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  9. #9 Re: air charge temp sensor
    Jun 2012
    baltimore
    napa isnt open on sundays and i have cut the other one off. advaced doesnt have it and upon stripping the wires i seen the ped 11 has 7 wires mine only has 6 wires just wondering if that will matter
  10. #10 Re: air charge temp sensor
    i used these guys for my pig tails, autowiringsolutions_aws | eBay if you dont see your pig tail, pm them, they will get right back to you, i also called and spoke to them.
    i got a maf and ait pig tails for about 10 each. shipped to my door in less then a week too. i was quite happy with their service.
  11. #11 Re: air charge temp sensor
    Jun 2012
    baltimore
    thank you for your help
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  3. Temp sensor?
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2011, 06:53 AM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
