Quote Originally Posted by Rich View Post
Low battery voltage can cause the key to stick in the ignition (not enough voltage to energize the solenoid that releases the key). I think the key stuck in the ignition is a symptom and not the problem. It sounds like you have either a bad battery, charging system, or something is drawing current when it shouldn't. Good luck!
Battery replaced within last 2 years -original lasted that long- didnt have that problem with the key when it died- Battery went from 90% charged to 25% by just trying to turn key and then the key wouldnt come out again- but ay 25% charge (according to my battery charger) it should have enough to engage a solenoid- but nothing would work again- but what could draw that much charge in seconds? No sound of anything engaging or drawing current.
