as for the key issue. i had the same problem for getting the key out. as it turned out, the plunger was dropping too far down when the ignition was turned on.i just used a small hose clamp wrapped around the solinoid, the same as tape. have never had a problem since.
i have a question about the traction control. is there a way to reverse the control so it is off all the time and needs to be turned on manually?
also, my air bag light is always on, normal?
