Thread: Key stuck in ignition lock cylinder
Results 1 to 20 of 69
  1. #1 Re: Key stuck in ignition lock cylinder
    the lock tumbler has nothing to do with any programming. thats between the key and ignition harness.
    if you now have a new key and lock, you need a old key, then you can reprogram the new key. or zip tie the old key under the column.
  2. #2 Re: Key stuck in ignition lock cylinder
    Jan 2017
    Texas
    Well that sucks since it was stolen while my wife had it warming up and the took the only key we had for it. It does run but the security light flashes for 10 minutes after start like it's going through the programming cycle. Guess we'll just deal with that and I'll yank that stupid solenoid out. Thanks.
  1. Master Cylinder Cap
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2008, 10:43 AM
  2. gtp cylinder heads
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:29 AM
  3. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
  4. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
  5. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
