Thread: how did i do with Cold air intake ?
Results 1 to 20 of 28
  1. #1 how did i do with Cold air intake ?
    May 2013
    United States
    i wanna know how i did from someone else with experience. PLEASE give me any ideas on how i can make this better .
    imgur: the simple image sharer
  2. #2 Re: how did i do with Cold air intake ?
    Cambridge, Ontario Canada
    technically there aint much cold air there. It should be extended into the front fender to grab "cold air"
    2005 E55 - stock
  3. #3 Re: how did i do with Cold air intake ?
    You could put the filter in the fenderwell.
    As is, you should notice better MPG, and less power in the city/low speeds.
  4. #4 Re: how did i do with Cold air intake ?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Remove the stock intake part.
    To keep it simple, you can just throw the cone on the throttle body and call it a day.
    Or look at my sig for reference as well.
    http://www.grandprixforums.net/simpl...res-33351.html
  5. #5 Re: how did i do with Cold air intake ?
    May 2013
    United States
    WhAt do you mean less power? Like less hp?
  6. #6 Re: how did i do with Cold air intake ?
    May 2013
    United States
    Quote Originally Posted by Elite6 View Post
    Is it fine as is or am i loosing hp
  7. #7 Re: how did i do with Cold air intake ?
    Jun 2011
    Your intake is fine.
    Its technically not a "Cold Air" intake, because it is not in the fender to grab the cold outside air or covered with a heat shield to protect it from engine heat.
    You wont see any more "gains" with a Cold Air Intake compared to your Hot Air Intake you have now. 90% of people on this forum run a Hot Air Intake because it's very simple, cheap, and effective.
  8. #8 Re: how did i do with Cold air intake ?
    You're getting hotter air, which means less dense.
    Which also means better fuel economy, and less power.
    Some will notice more sluggish performance at speeds under 40 MPH. Above that, it doesn't matter what intake you have. Unless it's a very well designed "ram air" intake.
    I've had a HAI, CAI, FWI, stock, modded stock.
    They all have ups and downs, but in the end, it's basically a waste of time and money.
    Benefit of current intake or a FWI would be the increased supercharger whine and more city mileage. Downside being less power in the city (which you probably don't need anyways).
  9. #9 Re: how did i do with Cold air intake ?
    Pennsylvania
    I follow the opinion of throw the filter on the tb, but if you wanna keep your pretty blue pipe, go to Home Depot or Lowes and buy a 3" to 3" coupler and put that on the throttle body, pipe on the other end, filter on the end of the pipe.
    I think either way though, you're not going to see any feelable difference, you might get some better sound by removing that baffled part... that's the part that's restrictive and makes turbulence in the air.
    Sport Edition Kv5 18x8
  10. #10 Re: how did i do with Cold air intake ?
    May 2013
    United States
    Should i take the stock rubber garmet thing off and just drill a hole for the sensor
  11. #11 Re: how did i do with Cold air intake ?
    Jun 2011
    Quote Originally Posted by mikey666 View Post
    That's what I would do.
    And keep this in mind, the closer the filter is to the Throttle Body, the louder the Blower whine.
  12. #12 Re: how did i do with Cold air intake ?
    May 2013
    United States
    Okay heres what im thinking. Could i honestyly just connect the cone right too the throttle body? Or just drill a hole in the pipe for the sensor? Do i need the sensor or can i hang it near the cone
  13. #13 Re: how did i do with Cold air intake ?
    Jun 2011
    You do not even need the sensor.
    You have a few options:
    1: Put cone on TB and leave sensor out.
    2: Put cone on TB and just put sensor basically inside filter. (In between filter and TB)
    3: Remove stock intake tubing, put the PCV piping you have on TB, drill hole for IAT. - (Recommended route).
  14. #14 Re: how did i do with Cold air intake ?
    May 2013
    United States
    Im gonna go with 3rd option but can i leave the sensor out? It wont effect anything?
  15. #15 Re: how did i do with Cold air intake ?
    Jun 2011
    You can leave the sensor out, I know people that run without it and have zero problems, but personally I have never done it.
    It takes 2 seconds to drill a hole for the IAT.
  16. #16 Re: how did i do with Cold air intake ?
    May 2013
    United States
    Okay will do that. But is the whine gonna be noticeably louder by removing stock baffled part
  17. #17 Re: how did i do with Cold air intake ?
    Jun 2011
    Noticeably? Eh, maybe.
    Will it be louder? Yes. But not by A LOT.
    There is plenty of ways to get the blower louder, and an intake is a good place to start.
  18. #18 Re: how did i do with Cold air intake ?
    May 2013
    United States
    What other pretty simple things can i do too make it louder.
  19. #19 Re: how did i do with Cold air intake ?
    Feb 2013
    37.295091, -121.930053
    mikey are you the devil? why did you pick 666?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  20. #20 Re: how did i do with Cold air intake ?
    Jun 2011
    Well, you can close the silencer ports but I've heard the reduces efficiency.
    http://www.grandprixforums.net/safel...ics-65065.html
    Port the blower.
    Here's some pictures of that:
    http://www.grandprixforums.net/porti...ips-70207.html
    Making the Blower pulley smaller, which makes the Blower spin faster, therefore is louder but read this first:
    http://www.grandprixforums.net/safel...0-a-67580.html
    Or do a Gen V swap. This blower is louder than a Gen III
    http://www.grandprixforums.net/eaton...5-a-49039.html
  1. Replies: 81
    Last Post: 02-14-2013, 02:57 AM
  2. Cold air intake
    By Bessesen2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2013, 11:27 PM
  3. Cold Air Intake
    By Summer Time Anytime in forum General Tech Discussion
    Last Post: 10-10-2011, 02:50 PM
  4. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  5. Cold air intake
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 09:52 PM
