Thread: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
Results 1 to 12 of 12
  1. #1 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Mar 2013
    Buffalo, MN
    97 GT strange grinding noise from drivers side firewall 2 seconds after starting, then it stops sounds like when antilock brakes kick in when sliding.
  2. #2 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Feb 2013
    37.295091, -121.930053
    welcome to GPF
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Welcome to owning a 97 GT.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Jul 2013
    san diego
    so what is the answer to this? im having the same issues
  5. #5 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    St. Louis
    Probably the EBCM doing a check on the ABS system. Sounds normal to me from what I've heard about the 97's.
  6. #6 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Newnan, GA
    ^ bingo.
  7. #7 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    its normal for the car to make the crunching / rake dragging sound when first started up and then driven.
  8. #8 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Jul 2013
    san diego
    here is what my GF sent me yesterday about the car
    I went out started it again it stayed on but sounds rickety in the engine kinda like something is clanking more high pitch than a knocking sound, I could smell some gas but not sure if it blew from the exhaust area. There is also a high pitch buzzing sound toward the rear of the car. I looked under didn’t see anything red. Shut it off, waited a few seconds started again it stayed on but still sounded crappy. I gassed it a bit the boost didn’t light up at all. I’m not going to mess with it anymore tonight.
  9. #9 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    St. Louis
    The high pitched buzzing sound is likely your fuel pump. Normal. Might need a fuel filter change if it's struggling to push fuel. That can make them louder than normal.
    Not sure about the tapping. Could be a number of things. Best to get a vid and post it here so we can hear it.
    If you haven't already, start your own thread in the 3.8 S/C section for more help. We don't want to clutter up this thread with unrelated tech.
  10. #10 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Jul 2013
    san diego
    thanks ill post there
  11. #11 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Jul 2013
    san diego
    i got nothing on that end...
    i did replace the coupler, no crackling/rattle/grind. however it did want to die until i hit the throttle cable from under the hood. im thinking a throttle pos sens or a fuel filter? thoughts?
  12. #12 Re: 97 GT strange grinding noise from drivers side firewall 2 seconds after starting
    Newnan, GA
    I would lean towards the fuel filter as maybe thats causing the pump to work more thus making the noise noticeable.
  1. Hissing noise on drivers side rear
    By Roxrockz in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 06:36 PM
  2. 2005 Grand Prix GT passenger-side air grinding noise?
    By Molokai in forum General Tech Discussion
    Last Post: 05-27-2012, 11:30 PM
  3. noise on drivers side
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2011, 03:39 PM
  4. crunching noise in front drivers side
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-01-2011, 11:13 PM
  5. Drivers Side Cooling fan making bad vibrating noise
    By WkDcLwNz in forum 5.3L V8 (LS4)
    Last Post: 02-19-2011, 10:22 AM
