Thread: crunching noise in front drivers side
Results 1 to 8 of 8
  1. #1 crunching noise in front drivers side
    SE Level Member tstaller2005's Avatar
    minneapolis
    ok I am not sure how to explain this, but when I am backing up mostly when I am backing out of my friends driveway that is at an angle, I hear this crunching kind of noise out of my drivers side front end. I am wondering what it is. I already had the front assembly replaces on that side and it still does it. Is it possibly just the brake pads adjusting as the rotor turns? I replaced my brake pads, but not the rotors so I am wondering if they are warped that maybe I am just hearing my brakes adjust to the warp. Anyone know?
  2. #2 Re: crunching noise in front drivers side
    Banned
    Apr 2011
    wv
    maybe bad struts. the sometimes creak and pop when theyre REALLY bad
  3. #3 Re: crunching noise in front drivers side
    strut mounts are plausible.
    I hear squeaks all the time doing a similar thing.
    Factory struts yet new sway bar links and LCA's.
    To be quite honest, you wont know until you get the car up and take a look to see whats going on under there.
  4. #4 Re: crunching noise in front drivers side
    Banned
    Apr 2011
    wv
    get the front end bouncing. if it doesnt make the noise it NEARLY rules out struts, cushions, and most of the bushings on the control arm.
  5. #5 Re: crunching noise in front drivers side
    minneapolis
    its not my struts, It only does it when I am backing up, and 99 percent of the time as I am backing down a driveway with an angle. I have bounced the front end and nothing happens
  6. #6 Re: crunching noise in front drivers side
    Banned
    Apr 2011
    wv
    sounds like brakes or transmission. check your fluid level after a drive with the car running and in park.
  7. #7 Re: crunching noise in front drivers side
    minneapolis
    Tranny is full. Its burnt but its full. I am assuming the brakes since the rotors are warped.
  8. #8 Re: crunching noise in front drivers side
    Banned
    Apr 2011
    wv
    only one way to know for sure.
  1. Rattle on drivers front side
    By boneman29 in forum General Tech Discussion
    Last Post: 04-09-2011, 05:03 PM
  2. Drivers Side Cooling fan making bad vibrating noise
    By WkDcLwNz in forum 5.3L V8 (LS4)
    Last Post: 02-19-2011, 10:22 AM
  3. front end squeaking/metallic noise on drivers side
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 07:36 PM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
